500whp stock block club
i would have to say though, those high HP dyno graphs you have there are pretty retarded. especially the first one. that is the most horrible turbo lag i have ever seen on a car. from the looks of it, it doesn't ever make peak torque. i mean, it would just be stupid to drive because once it hits full boost you are shifting again. as far as drivability is concerned, i would much rather stick with something that makes decent power with a much broader torque curve. for instance, i may be making only 310 hp at the wheels, but i make peak torque before those guys even start the dyno pull. i have 1.5bar boost before 3000 rpm. who is going to win on a tight street course, certainly not any of those cars.
Originally Posted by TrinaBabe
Once I make a few passes without any problems (Ignition, shifting, etc...) I am expecting a 10.80 @ 132-133 on street tires. After I hit that goal I will throw on some slicks and most likely a 50 or 75 shot and see what it does with a little giggle juice. I plan on hitting a 9 second pass on the stock motor.
!!That will be my goal when I have EVO!!
Looks like I will be joining this club.. Probably closer to 600whp, I intentionally left the bottom end completely stock, along with the head studs and other components..
I suspect the failure at those levels are due to fatigue and problems, durability of this engine is without question the best I've ever experienced.. But a bad tune or a bad tank of gas is where you have to be concerned.. I think the stock engine can withstand well over 600whp just not hitting that constantly..
For those of you who have doubt on how long a 500 plus HP stock block will last well my car is a daily driver and still going. Props to all those that have made it to the 500 WHP Club!!!!!
MY Mods: DNP Header, AEM EMS, AEM CD2I Ignition, Single coil system, 3" downpipe & Exhaust, Tial 40 mm Waste Gate, SMC Alcohal Injection, Exedy Twin Disc, RC 1000cc Injectors, 272 HKS Cams, Fidanza Cam Gears, Turbo ?
These numbers where on 93 Octane with alcoha injection on 29 PSI. See the graph it says it all.
Every time at the track I run mine to 9k presumably at over 500whp. This is with a completely stock bottom end with the stock head. Amazing.
I dont have any dynographs on mine but I am somewhat confident that I would be in this category. At 26 psi the car traps at 128-129 mph. I run mine now at 30psi but had ignition issues which are now hopefully fixed so I will see what the new MPH is at 30psi.
Stock Block, Stock Head (Aside from HKS 272/272 and headstuds)
GT35R, .63 ar hotside, small E-cover
Shearer Header, Shearer o2 housing, custom 3" turboback
MBC, Magnus Intake Manifold, Aeromotive A-1000 & Fuel pressure regulator, -10 feed lines, fuel rail, -8 return lines, 8 gallon fuel cell
Tial 44mm wastegate, HKS ssqv BOV, custom lower, and upper ic pipes, Buschur deluxe FMIC
AEM EMS
TRE Race Transmission, Stock Rear End, Stock Axles, Stock T-Case, Stock Front diff
As for reliability... I drive mine daily. I beat the hell out of it. I have had well over 100 passes on the motor without failure.
AEM EMS
Originally Posted by anjapower
I'm surprised that people have only pushed it to the mid 500s. There's plenty of Honda guys pushing the stock K20a2 from the RSX-S to 450whp+...and that's an 11.0 compression motor with an open deck aluminum block.
