Tranny Oil Change!!
Old Jul 23, 2006 | 08:37 PM
o6RSEvo's Avatar
Tranny Oil Change!!
Hey guys, how easy is it to change your tranny oil? Where is the fill/drain bolt located and is there a trick to pumping the tranny oil into the tranny? What should I use?
Old Jul 23, 2006 | 09:00 PM
nhsean69's Avatar
I hope that attached file helps out. Its really simple. I used a funnal with hose on the end and ran it down through the engine bay and into the fill plug.
Old Jul 23, 2006 | 09:02 PM
Sap12687's Avatar
BG Syncroshift or Penzoil Syncromesh
Old Jul 23, 2006 | 09:05 PM
bigric09's Avatar
the fill plug is just below your intake box... which is what is pictured... you can either use a funnel or use a fluid pump available at most car stores for about 10 dollars.... the pump is easier because the fluid is very very thick and 3 liters takes quite a bit of time
Old Jul 23, 2006 | 09:12 PM
idriveanevo's Avatar
whats the best fluid for easy shifting and durability? ive been told to use gm syncromesh.
Old Jul 23, 2006 | 09:17 PM
Evolved Monkey's Avatar
I've heard the oem diaqueen fluid is the best. If you don't have any complaints about the way your car shifted before then I would just stick with the stock fluids.
Old Jul 23, 2006 | 09:19 PM
Spec'd's Avatar
Here's a decent link. Allthough I'd rather use a pump instead of funnel.
http://evomoto.com/tech_info.php?tPa...6adc0bf179ad32
As far as tranny oil. Mitsubishi recommends GL4. I like 2 qts MT90 and 1qt MTL.
http://www.redlineoil.com/products_g...sp?subcatID=18
That's just my preference.
Old Jul 23, 2006 | 09:20 PM
i just want something to make it shift easier
Old Jul 23, 2006 | 09:22 PM
Spec'd's Avatar
For the differentials ... Yes
For the a 6 speed MR tranny ...Yes
For the 5 Speed tranny ... Mitsubishi sells bulk or 5 gallon drums.
In the owners manual Mitsubishi is very specific.
Old Jul 23, 2006 | 09:23 PM
Spec'd's Avatar
When was the last time you changed your tranny oil ?
Old Jul 23, 2006 | 09:24 PM
Doogie Howser's Avatar
diaqueen is used in the x-case and diff never in the transmission.
Use pg synocromesh or bg synocroshift..search
Old Jul 23, 2006 | 09:27 PM
around 6000 miles ago
Old Jul 23, 2006 | 09:38 PM
Spec'd's Avatar
A lot of members/owners use synocromesh or bg synocroshift.
It is NOT Mitsubishi's recommended GL4.
If Mitsubishi decides to do a chemical analysis ( which they do )
in the event of drivetrain failure, there can be a great chance of
a voided warranty.
For the MR 6 speed it is imperitive to use DIAQUEEN SUPER MULTI GEAR, or exact equivilent. http://www.lancershop.com/customer/p...&cat=15&page=1
Different from Mitsubishi GL5 LSD Gear Oil Diaqueen :
The recommendations are are SPECIFICALLY in page 7-12 in your owners manual.
Old Jul 23, 2006 | 09:47 PM
What about BG synchoshift II? would that fit the requirement for mitsubishi's standards?
Old Jul 23, 2006 | 09:54 PM
Spec'd's Avatar
Allthough alot of Evo owners swear by it, It's still not GL4.
Technically it doesn't meet Mitsui approval, it does seems to
make for smooth shift. I have to question how well it lubricates
the bearings in the tranny. The syncro's are a different issue.
I just prefer the redline. I've tryed them all. Once the tranny is warmed
up they all seem to work well.
That's just my opinion on the transmission oil. I love my Redline.
