stroker vs. overbored and head being addressed
ok i'm out of this, but just one question
are you two the same person or do you just sleep with each other? if there is such a huge knowledge base among you why are you even here trying to debate nits and picks? lame.
come with this hostile attitude and even though there IS TRUTH, you just wanna exude your narrowminded dominance over this--now-- totally ridiculous conversation/debate/flamefest that i don't wanna be apart of because you're jackasses.
Originally Posted by blackevo110
where does it say engineer???
I'm confused. All I know is that he knows his stuff (not that others, including yourself, don't). I was merely trying to point out that he isn't some 16 year old kid pounding away on a keyboard somewhere.
He has gotten in very technical arguments on here before, only to have the other person capitulate in the end. That's all I'm trying to say
Originally Posted by trinydex
hahaha... i think he engineers ic engines... their piston and their rods... as well as their cylinder geometry.
Homemade and friend keep talking about adjusting compression height to accommodate longer rod, but that alone introduces changes in the piston (point 2 earlier post). In addition there are again tradeoffs to narrowing up ring packaging and/or moving the pin up. This is on top of changes to rod also listed earlier.
There is no way to hold all else constant to conduct a pure rod ratio to rod ratio test. It has never been done before.
There is little use discussing anything anymore now that namecalling has begun. Can't discuss anything rationally or objectively with emotional people who do not want to stick to the points.
if you cant take the heat stay out of the kitchen...
this was a thread to find knowledge if you hadnt challenged and approached my friend like you did he wouldnt have to run circles around you. believe me ill be the first to admit i dont know anything about this...im a novice looking for the knowledge and so i posted...he has the knowledge and helped me with this thread. if u feel so overwhelmed go away, i dont need this debauchery.
also another friend was posting on my name...so if anything intelligent was said on my account name it wasnt by me.
thank you very much. I really appreciate that.
I don't want to keep ALL others as constants but to see the gains of the rod change in the 2.0 between stock and long rod. As obvisouly to see the changes you would have to change the tune as well (not keeping all things the same). Of course they can't all be kept the same as things as simple as port velocities (therefore pressure, think choke) would change. Not the inteneded point of the thread I percieve.
I don't know who is getting emotional and if I called a name I do appologize...I would like to continue the discussion as in college doing Formula SAE I became accustomed to proving a design point by being questioned by other engineers/designers much like in my job at NASA...makes one stretch their own thoughts and reasoning.
My whole reason for questoining/responding in the thread.
-Micah
p.s. Shaun you didn't answer about how the stroker kit and the manifold pressure ratio bits came along...I'm curious, please drop me a PM if you could.
Since the subject of rod/stroke ratio is being discussed here, here are a few examples that I've compiled:
2.6L Nissan Skyline – 1.41
Ford 2.5L SOHC truck - 1.49
2.3L (stroker) 4G63 - 1.5
Chevy 454 V8 - 1.53
2.4L 4G64 - 1.56
Chevy 427 V8 - 1.63
Chevy 350 V8 - 1.64
2.5L WRX STI - 1.65
3.0L Supra Turbo – 1.65
2.2L (late) Honda S2000 - 1.65
Ford 2.3L SOHC turbo - 1.66
2.0L 4G63 - 1.7
Ford 5.0L V8 – 1.7
2.0L JDM WRX STI - 1.74
2.1L 4G64 - 1.77
2.0L (early) Honda S2000 - 1.82
VW 2.8L VR6 – 1.82
Ford Taurus SHO V6 - 1.83
Chevy 302 (early Z28) - 1.9
Asiatech V10 3.0L F1 engine - 2.3
Originally Posted by Ted B
FWIW, I'm presently assembling a long rod 2.0. I'm not expecting anything truly tangible in the way of impoved power, but given the rpm range where I'm looking to maximize efficiency, it seems like a viable route.
not making a monster...if that were the case I would use a a 4G64 as it has more room to play with
Chevy 454 V8 - 1.53
2.4L 4G64 - 1.56
Chevy 427 V8 - 1.63
Chevy 350 V8 - 1.64
2.5L WRX STI - 1.65
2.0L 4G63 - 1.7
Ford 5.0L V8 – 1.7
2.1L 4G64 - 1.77
VW 2.8L VR6 – 1.82
Chevy 454 V8 - 1.53
2.4L 4G64 - 1.56
Chevy 427 V8 - 1.63
Chevy 350 V8 - 1.64
2.5L WRX STI - 1.65
2.0L 4G63 - 1.7
Ford 5.0L V8 – 1.7
2.1L 4G64 - 1.77
VW 2.8L VR6 – 1.82
Seems like generally as you work your way up the list you move from more 'torque monsters' to more 'high strung' engines.
basically all I would be looking for...better efficiency, more capability for higher boost, more NA power (out of boost/light around town power), capability of higher RPM . . .
From: City O Sin, MA...the not so sinish part though...
This is so funny. Aparently in your mystical world of engines, you don't have detonation or preignition.
Ever heard of "combustion chamber heat management" ?
It's a nifty thing where we find ways to minimize the amount of residual heat in the combustion chamber. How do you think detonation occurs? It happens because the flame front is ignited too early. The more residual heat the more likely to have detonation or even worse, preignition.
-Dominic on Black's acct still
First of all I am well aware of the causes and effects of detonation and residual heat in the combustion chamber. Using coatings, polishing the piston and head, smoothing out valve reliefs, running the right spark plugs, you do it to fight hot spots, which can cause preignition.
Secondly, residual heat has to do with the physical design, not timing, so I dont know why you started blabbing about that. You were talking about having a longer dwell around tdc being good because you dont have to ignite the charge as early. If your piston isn't hanging around tdc as long you can get away with earlier timing.
It sounds like you're looking for better everything. FWIW, if better low rpm efficiency is desired, lengthening the rod would seem to be going in the wrong direction.
+1 for being shocked by how short the RB26's rod ratio is...
The shorter rod quickens piston acceleration from TDC. This gets the air column moving more quickly at low piston speeds, which improves filling of the cylinder and increases VE. Naturally, there are other factors that influence this, but that is the crux of it.
