6 speed + non oem fluid = bye bye tranny
Old Aug 3, 2006 | 02:46 PM
NoTec's Avatar
Originally Posted by 91TB78
Driver gingerly for awhile. Don't beat on it while it's cold. You can also go through the gears slowly and double-clutch to get your drivetrain warmed up.
A good rule of thumb is your drivetrain is warmed up once your engine oil is warmed up, but usually under the assumption that you're not just idling, but actually driving around to warm everything up.
+1 on the warm up
Most athletes dont take the field or court and go ***** out without warming up first. Why not apply that to your car. Only seems logical.
Old Aug 3, 2006 | 03:10 PM
sonicnofadz's Avatar
Originally Posted by revvin9k
How are you supposed to warm up your drive train fluids?
There are some gears/shafts spinning even while in neutral idling, so the tranny fluid does warm up a small amount while the engine is warming up. It is probably best to be easy on the drivetrain for the first 5 minutes of driving (no 6k dumps!)
Old Aug 3, 2006 | 03:13 PM
CICreations's Avatar
Move the shifter back and forth left to right in neutral as fast as you can for a good 2 or 3 minutes, that should do the trick.
Old Aug 3, 2006 | 03:18 PM
TTP Engineering's Avatar
Originally Posted by AutobonEvo
go with penzoil syncromesh......shifts like butter
Yeah, until this happens to you. $4571 out the window.
Old Aug 3, 2006 | 03:23 PM
WarmPepsi's Avatar
yeah, i'd consider 90 degrees ambient, warmed up for about any fluid.
sure, you don't start and go out and drop the clutch, you run a few laps at lower speed, gotta heat the tires up.
Old Aug 3, 2006 | 03:38 PM
Youch! Keep in mind the 6 speed MR tranny is alot weaker (structurally) than the 5 speed.
Old Aug 3, 2006 | 03:45 PM
lowbdgtmechanic's Avatar
yea, i go by the temp...if it goes up 1/4 from 0 then i think its warmed up...however my evo warms up way faster than my other car[96corolla] and so other new cars civic, tc.
Old Aug 3, 2006 | 04:55 PM
RazorLab's Avatar
So much information in this thread my head hurts
c.scatena
Jan 5, 2016 04:28 PM
silver9mr
37
Jul 1, 2014 12:58 PM
17579EVO9MR
Apr 4, 2012 06:30 PM
yitzac1990
Lancer Aftermarket Forced Induction Tech
Dec 25, 2010 09:52 PM
Spins4
Sep 17, 2010 04:32 PM
