Hi-Flow Cats causing CEL; solution?
Old Aug 5, 2006 | 08:40 PM
brokenRS's Avatar
Right now i currently have a Helix 3'in Hi-Flow cat, i purchased the car with it on and a HKS HI-flow exhaust system. Went to autozone today and got the code scan "P0420" When i ran a friend with a S2000, when i took the lead he told me everytime i shift, smokes would shoot out, not much, but enough where he can see it clearly, The question is, is this bad for my car? Should i go on eBay and purchase those O2 sensor spacers? but if i do how would i know the furture damage of my cat. Is there any other better solution? I've tryed to search many time, but never got the result i needed. Anyway if i can get any tips would be great, thanks
Old Aug 5, 2006 | 11:49 PM
byt's Avatar
byt
your searching skills could use some work
https://www.evolutionm.net/forums/sh...d.php?t=208195
Old Aug 6, 2006 | 12:03 AM
Danny23's Avatar
get a perrin 02 simulater, no more cel
Old Aug 6, 2006 | 12:05 AM
evojacko's Avatar
get the anti foulers. it costs about 2 bucks and its one of the easiest things you can do to your car. unless the o2 sensor is stubborn. which is common.
Old Aug 6, 2006 | 12:06 AM
brokenRS's Avatar
Yeah i saw that thread, my searching skills are fine. still doesnt answer my question
Old Aug 6, 2006 | 12:07 AM
elhalisf's Avatar
go under ebay and search for evo cel
its a spacer you put inbetween the sensor and exhaust. in the 10 months i have had the car, i have NEVER got the cel light from the exhaust
Old Aug 6, 2006 | 12:08 AM
brokenRS's Avatar
yeah, that what i have in mind non-foulers, perrin are kind of costy
Old Aug 6, 2006 | 12:09 AM
brokenRS's Avatar
would the non-foulers work just the same as the eBay ones?
Old Aug 6, 2006 | 12:15 AM
evojacko's Avatar
i havent looked at the ebay ones. i have the anti foulers on my car and my p0420 codes stopped. just drill one with a 1/2 inch drill bit then screw it into the other one and you're good to go. simple mod. in theory it takes about 10 minutes. unless you are using an ancient drill press that doesnt tighten down on the bit very well.
