just installed 20g 9 5 overboosting?
Old Aug 7, 2006 | 07:26 AM
  #31
94AWDcoupe's Avatar
The actuator is not getting a boost signal. Or the diaphram is blown. those are really the only two possibilties. Check for a leak in the line. You can check the diaphram by using a cheap vacume tool. They dont hold 100% so you need to compare the results next to a known working one.
Old Aug 7, 2006 | 11:55 AM
  #32
matt55's Avatar
Originally Posted by dreaminevo
35 psi wont blow your motor on one pull . i boosted my stock motor/ turbo to that 3 times trying to set my boost controller . the only thing that it messed up is it stretched the spring in the wastegate so it only hold 12 psi without the controller
Never ever tell ppl that it is ok to run 35psi+pump gas
12psi is the wga spring pressure , u didnt stretch anything .....
Old Aug 7, 2006 | 12:04 PM
  #33
C6C6CH3vo's Avatar
I agree, bad advice to boost 35 psi. 25 psi on pump gas can crack a piston, 19 psi can too with a bad tune.
WGA spring wont stretch from it either, the WGA after bleed hole and MBC will never see manifold pressure.
Thanks for the input however.
Old Aug 7, 2006 | 12:07 PM
  #34
deadbeatrec's Avatar
24 psi is his wastegate pressure. he has the upgraded actuator.
Old Aug 7, 2006 | 12:13 PM
  #35
dustin03's Avatar
I am trying to find someone to trade with for a stock 9 wastegate
Old Aug 7, 2006 | 11:13 PM
  #36
dreaminevo's Avatar
i didnt say ot was ok to i just said i accidentally did it and it didnt ruin anything . and my stock boost was 22 psi falling off to 19 . the car runs 10:1 air fuel under boost. i also have no tune the car has the big 16g its a later model 8 so it the same as a 9
devildevil
For Sale - Part Outs
42
Aug 10, 2014 04:43 AM
devildevil
Aug 7, 2014 11:30 AM
Flying
For Sale - Cars For Sale
Jul 22, 2014 07:34 PM
devildevil
20
Apr 24, 2014 06:45 PM
Spoolin18
32
Dec 9, 2013 07:36 PM
