Is this normal after TBE install ?????
Old Aug 7, 2006 | 09:21 PM
derangedazn's Avatar
I just got finished installing a Turbo XS TBE (3 inch DP with stock CAT) on my 05 Evo. The two tie bar for the subframe does not fit back in due to DP. Is this normal? What I am trying to ask is will there be any problems if they are not placed back on. I know most of you have TBE and I was wondering if you were able to put those tie bars back on.
Just making sure so I do not damage anything . Thanks
Old Aug 7, 2006 | 09:23 PM
ovelezs's Avatar
You can get some spacers for the tie bars.
Old Aug 7, 2006 | 09:25 PM
hondafan's Avatar
or use a stack of washers, spacers are nicer though.
Old Aug 7, 2006 | 09:28 PM
where do I buy those at? ....like Auto Zone?
Old Aug 7, 2006 | 10:54 PM
tony_b's Avatar
Take one of the bolts to the nearest hardware store. If you can't find a spacer, buy a bunch of washers.
Old Aug 7, 2006 | 10:59 PM
JohnBradley's Avatar
The TurboXS TBE comes with like 6-8 spacers of varying thickness. Least mine did.
Old Aug 8, 2006 | 03:51 AM
Turbo Meg's Avatar
+1 mine as well!
Old Aug 8, 2006 | 08:01 AM
ok I got those as well...just wasnt sure what to do with them...thanks. I will give them a try
Old Aug 8, 2006 | 08:21 AM
Warrtalon's Avatar
Laf, you got the hardware then didn't use it? Funny stuff. You should have spacers AND longer bolts, because the stock bolts aren't long enough if you use a thick enough spacer.
Btw, it's not a TBE if you have the stock cat. A TBE is the entire exhaust from o2 housing back...just FYI.
Old Aug 8, 2006 | 08:56 AM
dan628's Avatar
You can get the Cusco V1 and V2 lower arm bars that fit with aftermarket downpipes and add more support than the stock bars provide.
Old Aug 8, 2006 | 11:01 PM
Thanks guys.....And Warr.....I no absolutely nothing about cars....more medically minded. I am attempting to learn......School takes up 95% of my money..the rest goes to living expenses and gas. You dont know how long I had to save to get the freaking exhaust. I guess it will be baby steps for me...but soon
