Stock clutch & Gear Lockout?
Old Aug 17, 2006 | 04:34 AM
cij911's Avatar
Folks,
I have searched and find mostly ACT issues, so please no flaming LOL...
I have an 06 MR and occassionally find that the car does not want to be shifted quickly (when warm, I don't drive the car hard when cold). I never have a lockout problem when shifting slowly and letting the syncros do their thing. Is this a known clutch issue? I am not grinding gears, but the tranny is just letting me know that it does not want to go into gear ...It is frustrating because it usually happens at the most inconvenient times (when really driving hard) and can be a major disappointment.
Yes I know how to shift, yes it has happened when matching engine / trans revs, no the tranny is not cold
Thanks in advance.
Old Aug 17, 2006 | 06:52 AM
nrcooled's Avatar
Yes, it is a problem and an engine damper or front motor mount will help. These are not fool proof and you still have have issues but they help alot. There is a considerable amount of noise you have to deal with by installing either one but they help with the shifting.
I have a Stillway ED and it definately helps. I only run it when I am at the track since it makes soooo much noise.
Old Aug 17, 2006 | 07:12 AM
lcakes05's Avatar
i adjusted the the clutch pedal on my aftermarket clutch and it helped out alot you should atleast try it. go to evomoto.com for instruction, hoped that helped.
Old Aug 17, 2006 | 08:29 AM
19psi's Avatar
+2 on the clutch pedal adjustment.
When I had a 03, I had gear lock out occasionally but after adjusting the pedal it never happened again.
On the evo9 I have right now, I adjusted the clutch pedal the second day I had it because the engagment was too close to the floor.
I have zero gear lock out issues and shifts great.
Old Aug 17, 2006 | 08:39 AM
Smike's Avatar
+3
Heres the link:
http://evomoto.com/tech_info.php?tPa...427a13a7011058
Old Aug 17, 2006 | 08:44 AM
cij911's Avatar
Thanks a ton guys....I will adjust this PM....
vboy425
10
Oct 30, 2016 06:50 PM
tehSteve
Jun 30, 2011 06:16 PM
tehSteve
Oct 17, 2010 02:39 PM
recompile
148
Jul 12, 2009 09:23 PM
KazzEvo8
10
Jan 24, 2007 12:37 PM
