RPM specific rattle
Old Aug 19, 2006 | 05:00 PM
ilikedirt's Avatar
RPM specific rattle
First off. I searched, but couldn't find anything completely relevant to my problem.
I have a fairly loud rattle. It only occurs at ~2400-2600rpm and occurs in each gear. Other than that there is not a similar condition. I have datalogged while driving and engine parameters do no change or flux in congruence with the rattle.
I have checked all my exhaust parts and they are all tightened down and everything has clearence. I checked over things in the engine bay and everything looks fine. My upper IC pipe is sittting against the driver fender well but if I knock it against the car it does not imitate the sound I hear while driving.
The car only makes the sound on the road. I put it on the dyno and the sound never appeared which leads me to believe it's a rattle.
I recently put in the AMS 2.3L stroker and have all bolt on and cams. The noise just appeared after the engine install. I had the shop look over the car extensively 3 times and they couldn't find the source of the noise.
I am at a loss. If anyone has any ideas, please let me know. Or if someone can reference a thread dealing with this problem that I may not have seen that would help too.
TIA
Old Aug 19, 2006 | 05:19 PM
ilikedirt's Avatar
bump
Old Aug 19, 2006 | 08:12 PM
ilikedirt's Avatar
Does nobody know, or does nobody care.
Old Aug 19, 2006 | 09:15 PM
Zeus's Avatar
I have a similar issue I'm lookin into...
Old Aug 20, 2006 | 10:10 AM
ilikedirt's Avatar
bump
Old Aug 20, 2006 | 12:30 PM
JDMevoBOOST's Avatar
exhaust related rattles are rpm dependent
Old Aug 20, 2006 | 12:59 PM
uterus!'s Avatar
I just found my rattle I have been dealing with since I bought my car.
It turns out the heatshield that is above where my cat goes was loose. When I went to tighten the bolt it snapped off with very little force. So the bolt was cross threaded from the factory and was never fully tight.
I used tiny sheet metal screws and secured it to the 2nd shield under the main heat shield being careful not to drill into the floor.
So far so good. No more rattles.
Old Aug 20, 2006 | 01:24 PM
scottatyamaha's Avatar
Could be the engine counter balancers
Old Aug 20, 2006 | 09:19 PM
ilikedirt's Avatar
You mean the Balance Shafts? I didn't think of that. I had the balance shaft eliminator kit applied so maybe that's it.
Old Aug 23, 2006 | 04:26 PM
any luck?
Old Aug 23, 2006 | 04:45 PM
ilikedirt's Avatar
no luck. I give up. The car drives fine so unless I run into a problem I'll just crank up the system and ignore it.
xXConnartistXx
Jul 21, 2015 01:45 PM
dxlykos0131
Dec 8, 2013 07:59 PM
Frew
Jun 10, 2013 05:51 PM
Travenport
Jun 7, 2012 10:41 PM
Jdmredline32
17
Jul 15, 2011 11:12 AM
