supertech valve spring specs
Old Aug 21, 2006 | 01:06 PM
althemean's Avatar
Anyone have the specs for the singles and the duals? I tried the Supertech website but it does not list the info. The searches on here did not provide any real results either.
Thanks for whoever can provide the info.
Old Aug 21, 2006 | 04:31 PM
althemean's Avatar
Not the info I was after but thanks. I want the seat pressures, coil bind dimension, ect.
Old Aug 21, 2006 | 07:56 PM
althemean's Avatar
whos got the info??
Old Aug 21, 2006 | 08:10 PM
TTP Engineering's Avatar
Ted B. I suppose...
Old Aug 22, 2006 | 07:10 AM
94AWDcoupe's Avatar
stock evo seat is 52lb
stock dsm is 62lb
crower 69lb
new briancrower 80lb? (website says 95 at 1.5, but seat height is nearer 1.6)
supertech 78lb
ferrera dual 90lb
supertech dual 95lb
There is much info from dsm boards about how high stock dsm springs can rev without hurting things. many logs of over revs in the 9-10,000 range.
The stock evo setup is better than the stock dsm springs. The behive springs and 4 gram retainer has less mass to control than dsm springs. I weighed the valve, spring, retainer, and lifter on both evo and dsm and the evo has a better mass to spring pressure ratio. And that is not including the fact that the whole spring is not being moved, only the top half. The behive spring is much lighter at the top half.
In short the stock evo setup rocks. Less friction, less heat, more horsepower. In addition to light but effective seat pressures the bottom of the retainer of evo spring comes very close to the valve stem seal. So in the case the engine is overevved the seal acts like a bumpstop. Mitsu engineers are smart.
There is a guy that just made 850whp on briancower springs/retainers/280s on a high rev 2.0.
Old Aug 22, 2006 | 07:58 AM
althemean's Avatar
Thanks. I wanted to compare the Supertechs to the BrianCrower (which I just purchased) for use with my JUN 264's. I read a few good reviews of these springs and the price was right to include the Ti retainers.
Old Aug 22, 2006 | 08:15 AM
Kee1pride's Avatar
what kind of lbs are we looking at for JUN and revolver's springs and retainers?
Old Aug 22, 2006 | 10:45 AM
Zeus's Avatar
For Revolvers:
Originally Posted by mttam510
Lo (free length) : 47.74mm / 1.879"
L1 (installed length): 38.1mm
F1 (installed load): 75 lb/in
L2 (working/valve-open length): 27.3mm (HKS) 26.6mm (Revolver
F2 (working/valve-open load): 163 lb/in @10.8mm (HKS) 172 lb/in @11.5mm(Revolver)
Sc: (spring rate): 214.6 lb/in
Lc: (block/closed/coil-bound length): 23.5mm
Fc: (block/closed load): 206.8 lb/in
Go to: https://www.evolutionm.net/forums/sh...ings+retainers
for a good read on them... post#192 is where the actual specs discussion starts. I also believe they allow one of, if not the highest lift in an aftermarket off the shelf spring.
Old Aug 22, 2006 | 11:26 AM
Kee1pride's Avatar
thanks bud
surferjeff
11
Apr 11, 2015 12:11 PM
Stellybeats
Dec 22, 2014 11:13 AM
Rex915
Jun 12, 2011 05:38 PM
Xenope
10
Sep 21, 2010 10:32 PM
1320 Engineering
Sep 21, 2008 06:59 PM
