My 2.3L build, lots o pics
Old Aug 29, 2008 | 03:54 AM
  #226
peteformance's Avatar
really good pics and really good job bravo .......
Old Aug 29, 2008 | 04:29 AM
  #227
piotr4net's Avatar
realy good job
Old Sep 12, 2008 | 07:30 AM
  #228
Rob_GPT's Avatar
Just so I'm clear. Do you use stock size rods and pistons? I'm trying to source them and the link from way back on page 3 is dead.
Old Sep 12, 2008 | 07:52 AM
  #229
jid2's Avatar
Rods are stock sized, pistons are stroker specific. If you are confused you should talk to a knowledgeable vendor to source the parts. There is WAY more to doing the stroker than just rods, pistons, and a crank. I know, I'm in the middle of it!
Old Sep 14, 2008 | 07:40 AM
  #230
Rob_GPT's Avatar
Rods, pistons, crank, and balance shaft elimination... what more is there? (Other than obviously the stuff you have to do any time you build a motor cuase i've been there before)
Old Oct 2, 2008 | 01:09 PM
  #231
oneofakindtrini's Avatar
awesome build. is that the factory turbo?
Old Oct 2, 2008 | 01:54 PM
  #232
TIBOevo's Avatar
lets get a vid of the car running. i wanna hear what it sounds like.
Old Oct 17, 2008 | 10:00 AM
  #233
850RCT9A's Avatar
Good job bro. Your work looks great. As soon as I get my block back from the machine shop I will be building a 2.3 as well, with a long list of other parts.
Old Oct 17, 2008 | 08:20 PM
  #234
3G4LIFE's Avatar
Nice!!!
Old Oct 29, 2008 | 06:07 PM
  #235
linlan's Avatar
oho.
Awesome.
I will do my build one day.
lol
Old Nov 17, 2008 | 08:55 AM
  #236
chrisdebruin's Avatar
Evo 6 Gsr
Hi Guys
I own a EVO 6 GSR and recently built my engine with Stroker comp pistons, rods and a stroker crank bringing the CC to 2.4Lt.The cams are Blitz light weight with a little delayed lift.The ECU is a Reflashed evo 8 ecu with a carbon copy Ralliart program.The turbo is standard evo 6 with standard wastegate.
The problem is with the Apexi AVCR i am only getting 1.2 bar boost on 1st and 2nd gear and 1.5 bar boost on the rest of the gears.Can somebody help and tell me how i can increase the boost to spike to max boost and then taper it down.When the vaccum hose is removed and we do a run max boost is 1.7 bar
Also the AVCR is showing a negative boost when the engine is switched off and on ACC mode.
Can somebody advise pls
Thanks
Chris
Old Nov 23, 2008 | 07:33 PM
  #237
sniper3818's Avatar
I would like to see this setup with a fp red
Old Dec 23, 2008 | 11:44 AM
  #238
skatermsmn's Avatar
Originally Posted by 9GUY9
Ya I did trade it at Freeway Ford.
I heard that it was involved in a crash that took out the front or rear bumper, while being driven by a employ, shortly after i traded it in.
I've always wondered where the car ended up, and what has been done with it.
Ya when I drove it, It was in really bad shape. The dipstick wasnt even in and there was oil all over the underhood and engine and it was really low on oil. I would have picked it up if it wasnt beat on like it was. I also noticed that the abs,engine,oil light all came on when I took it for a test drive and I told the dealer that this wasnt good and he said to keep driving it.
Old Dec 29, 2008 | 06:41 PM
  #239
BKaulitz's Avatar
i wana get mine upgraded to 2.3 soon too
Old Jan 14, 2009 | 08:19 PM
  #240
humgaling12's Avatar
great write up man. This is definately motivation for me to build my motor!
