A/F guage in AFR??
Old May 2, 2003 | 11:23 PM
Evilution's Avatar
A/F guage in AFR??
Is there an AFR out there that has a built in A/F guage? Kind of like the EBC has a built in boost guage. I'm trying to keep my cabin as clean as possible without a bunch of stand out guages. 1/4 din units are easier to hide and look stealth inside with.
Old May 2, 2003 | 11:31 PM
MalibuJack's Avatar
Although I don't know of any specific AFC product, you can "Monitor" sensor (and in turn, monitor the O2 voltage) voltage using the Apex'i S-AFC products, but it requires a creative use of a spare sensor lead. I have seen 2 products that come close to what your looking for from a stealthy point of view.. http://gadgetseller.com/gauges/ this company sells a digital A/F voltage gauge, it works with narrow and wideband O2 sensors.. I had mounted one in place of the digital clock on my car, but I have since removed it, for no other reason than I wanted to keep all of my stock accessories working. Another product is more of a "idiot light" style gauge, and its also good for tuning, its made by a company www.dawesdevices.com Both products are very good, but I found the latter to suit my needs better when used in conjunction with the S-AFC in monitor mode.. and an OBD-II Data logger to capture O2 sensor voltage etc...
Old May 3, 2003 | 12:17 AM
Evilution's Avatar
Woa, thanks Malibu. That Dawes Devices one is pretty swift. Very stealthy and small. Just kind of weird using a light system. I'll check around and see if anything else catches my eye. Thanks for the links.
Old May 5, 2003 | 04:27 PM
Z1 Performance's Avatar
Pivot used to offer a nice one - came with its own display unit (digital) and 02 sensor, though now its an analog version (60mm gauge, like the GReddy).
The one we really like now, and have used is the FJO kit, which we offer for $550.00 (lead time is usually 1 week).
I have found it works remarkable similar to the Horiba wideband I bought myself a few years back to tune the Z with (and its literally 1/4 the price of what I paid for the Horiba!)
Adam
Z-1 Performance
www.z1auto.com
Old May 7, 2003 | 12:33 AM
AustinEvo8's Avatar
Doesn't DEFI offer one?
Old May 7, 2003 | 01:56 AM
Evilution's Avatar
Link please.
Old May 7, 2003 | 08:08 PM
Ibiza013's Avatar
I think an EGT gauge its a much better idea since you will get an accurate Mixture reading and you can use it for tunning...all those non-wideband A/F gauges are just pretty much show.
Old May 8, 2003 | 11:45 AM
Defi does not offer an Air Fuel guage.
EGT is a good tuning tool, but in and of itself does not tell you at all how rich or lean it is. However, when used in conjunction with a datalogger, it provides very good info, since you can correlate TPS, boost pressure and EGT's together as well as ignition advance (or lack thereof, since OBD2 loggers will not show "knock" as far as I know at least.
The FJO kits we offer are great units - completly integrated wideband moniters.
Old May 9, 2003 | 09:36 AM
MalibuJack's Avatar
Although most OBD2 loggers don't log knock (because its not a standard sensor) I recall seeing that there is a Knock sensor reading that can be made within the OBD2 diagnostics.. Therefore if someone has logging software capable of using custom codes, you can set it up to do that.
Old May 9, 2003 | 01:50 PM
actually I think Defi have, or had offered an A/F guage, but I could have sworn it was analog...like the GReddy and Pivot units
Old May 10, 2003 | 10:50 PM
AustinEvo8's Avatar
You can still get the PIVOT with O2 sensor and digital display.
Old May 10, 2003 | 11:02 PM
AustinEvo8's Avatar
Bootys Evo
Aug 24, 2015 11:07 AM
OX
Aug 29, 2009 02:10 PM
crypto
Lancer Engine Management / Tuning Forums
May 8, 2009 12:16 AM
►EvolutionX◄
Apr 14, 2009 10:32 PM
smokedmustang
211
Mar 16, 2006 04:51 AM
