Intake manifold explosion! Alcohol possible cause?
Old Sep 6, 2006 | 06:26 AM
  #46
240Z TwinTurbo's Avatar
Originally Posted by Fourdoor
#4 How much are you offereing? I thought of having it repaired and then selling it, but if it failed again the buyer would fined some way to blame me.... if you want to purchase it "as is" and do your own repair PM me with an offer
Keith
It shouldn't cost more than $100 to put on a new plenum made from 1/8" 6061. Either reinforce that edge with angle aluminum or overlap the edge by 1/2" as shown below.
Old Sep 6, 2006 | 07:01 AM
  #47
dryad001's Avatar
Originally Posted by TheGVR4kid
How come the velocity stacks don't look like the pretty CNC'd one that they've always advertised?
My thoughts exactly.
Old Sep 6, 2006 | 07:02 AM
  #48
BADEVO's Avatar
Actually the 3rd or 4th one of these I have seen, its not that uncommon.
http://www.4g63hp.com/forums/attachm...5&d=1135914298
http://www.4g63hp.com/forums/attachm...6&d=1135914304
Old Sep 8, 2006 | 07:01 AM
  #49
Fourdoor's Avatar
Those are not velocity stacks.... they are just the ends of the runners. They did not offer velocity stacks 3 years ago when I purchased mine.
Keith
Old Sep 8, 2006 | 07:22 AM
  #50
stevEVO8's Avatar
This is probably due to the methanol puddling in your intake. The meth would not have necessarily been consumed in the explosion, the explosion could have blown out the available o2 which would result in the left over meth in the intake.
Old Sep 8, 2006 | 07:30 AM
  #51
Shearer's Avatar
This was obviously caused by some sort of backfire, I really don't care to speculate how it happened. One thing to keep in mind though, when instances like this happen it is not a bad thing to have your intake manifold blow apart like this. Something has to be the weak link when this happens. Whether it's an intercooler endtank, intake manifold, pressure making it's way through the turbo, or a ring land on one of your pistons. Take your pic on what you'd rather have. Personally I'd like to see the intake manifold or intercooler let go.
Old Sep 8, 2006 | 07:48 AM
  #52
stevEVO8's Avatar
true
Old Sep 11, 2006 | 08:37 AM
  #53
Ted B's Avatar
I agree. This appears to be a result of a backfire.
Keep in mind that modern port injected manifolds (including aftermarket jobs) are designed to be run dry. When injecting any liquid, some puddling should be expected. Likewise, unlike the stock setup, the mixture in the manifold is explosive, and is subject to ignition if something causes a sparkplug to fire at the wrong time (i.e. while the intake valve is open). When this happens, the explosion will cause a rupture of the weakest link, which in this case is the manifold weld. The force of the explosion is also probably to blame for the failed injector o-rings, but the weld gave because the leakage past the o-rings wasn't enough to contain the pressure the resulted from the explosion.
It might not be a bad idea to check the TB and the integrity of that shaft seal, and vacuum lines as well.
Old Oct 27, 2006 | 11:41 AM
  #54
maximumpsi's Avatar
Meth/alcohol keeps anything it contacts nice and clean
Old Nov 2, 2006 | 01:52 PM
  #55
version 2 beta's Avatar
I had the same thing happen to my weapon R intake manifold at GT Live. I was running around 30psi. same setup too... GT35r with alky.
It didn't blow apart as bad as yours but it blew open in multiple places though... Like along all the stacks and plenums!
Old Nov 9, 2006 | 04:45 PM
  #56
Magnus's Avatar
Meth
Methanol injection explosions, are actually very common these days, as the popularity of Meth injection rises. Meth injection backfires behave exactly like a nitrous backfire.
When you load up the intake manifold with fuel, and you have a rich misfire, you will experience just this.
Clear evidence is the birthing of the plenum, only an sudden tremendous amount of force could have caused that.
With small backfires, the plenum usualy retains its integrity resulting in only small amounts of distortion. You can never how bad your backfire will be, all you know is BANG, and your car is usually bouncing off the rev limiter. The best thing to do is program in fail safes through your engine management, and gradualy step it in, making sure to not run too rich, always making sure your ignition system is in optimum condition.
That was an early model there in the pic, newer plenum's have added features to protect you in case of large backfires. extar features include: internal welding, thicker material, and external bracing as well. They have been tested to 130psi of pressure, on the bench with using nitrogen. The have a hard time sealing gaskets past 90 psi.
Old Nov 10, 2006 | 06:09 PM
  #57
EnzoFerrari's Avatar
That is in no way Magnus's Fault...
Welds are not to blame.
What happened was as marco stated a rich misfire..
It could also have been a lean backfire. Both cause tremendous amounts of force in the intake manifolds.
i have datalogged upto 84psi in one of my intakes before it blew apart like a can of sardines. It's a good thing the intake went as i have seen even worse conditions. It could travel all the way back to the turbo and kick the nut off the comp wheel and destroy your turbo. I rather weld up a new intake then replace expensive turbo's or other parts...
Old Nov 16, 2006 | 09:40 AM
  #58
nutrulz's Avatar
Recently had a meth backfire, and it destroyed my IAC. What can be done to prevent meth backfires?
Old Nov 16, 2006 | 09:44 AM
  #59
scott yo's Avatar
OMG! That is crazy!
Old Nov 16, 2006 | 12:24 PM
  #60
BlackMK4's Avatar
What are the holes that appear to be drilled in it for?
