adjusting tilton clutch
Old Sep 4, 2006 | 03:28 PM
superflyevo's Avatar
ok,
well i got the tilton in friday,got the clutch broke in .
i adjusted it to were the instructions said too
i keep on getting the 7k lockout
i adjusted it out more still getting the 7k lockout
if i shift befor 7k it works fine i can even do the no lift shifting and it works fine
should i adj it more out
i already got it adjusted inch and a 1/4 off the floor and it says im only supposto
have it 1/2 inch
Old Sep 4, 2006 | 06:33 PM
anyone?
Old Sep 5, 2006 | 09:39 AM
03EVO583's Avatar
It sounds like you may be over-stroking the clutch. If you pass the clutch's release point, it will begin to re-engage (drag). The best way to find where to set the pedal stop is to:
1. Put the car into gear (without pressing on clutch pedal)
2. Have someone try to rock the car while you slowly depress the clutch pedal.
3. Once the car begins to roll, note where your pedal position is.
4. Typically you will need another 3/8" of pedal travel after initial release (step 3). Set you stop there. Only "fine tuning" should be needed from this point.
Originally Posted by superflyevo
ok,
have it 1/2 inch
Old Sep 5, 2006 | 12:27 PM
i tryed that
i bearly goes in gear
Old Sep 5, 2006 | 02:31 PM
well tinkered with it for a hour or so
its working fine now
Old Sep 5, 2006 | 07:58 PM
kjewer1's Avatar
So what was the solution? I'm sure we're all glad that you tinkered with it, and that it's workng fine now, but I personally only care about what the fix was in case I need it someday
Old Sep 6, 2006 | 12:53 PM
like 03 evo 538 said it is supposto be adjusted 3/8 of a inch out
well i got ming a full inch out
so i just adjusted mine out a lil further than normal
recompile
148
Jul 12, 2009 09:23 PM
Turbo Kyle
Apr 27, 2008 10:33 AM
twinscrewed
10
Aug 14, 2007 01:32 PM
Jack @ EvoStore
Oct 2, 2006 07:33 AM
SiCKlEyWiKeD
Feb 7, 2006 04:00 PM
