Had compression test done - numbers...
Old Apr 18, 2007 | 07:41 AM
  #31
MitsuJoe's Avatar
Isn't there some 05's too that have a problem with the water pump too?
Old Apr 18, 2007 | 09:19 AM
  #32
C6C6CH3vo's Avatar
Originally Posted by nj1266
I am wondering if the coolant leak is related to the low compression on number 3?
Low compression on #3 probably wont cause the leak, but that leak likely caused the #3 to go down hill. Problem is mitsu has a way too broad window of compression differential for their Evo.
Also looks like leak occurs at higher cyl psi/temps and perhaps some of the escaped pressure found it's way into the wet side (via #3 HG area) and out the path of least resistance - where you see leaking.
You might diagnose this one with a leak down as follow-up to your compression test.
In this case mitsu ows you a head/gasket replace, I think this happened to someone else but it was a PITA for him
Nonetheless, hopefully rings or valves are good cuz overheating will make engine knock up a storm - I found this out with a jeep rental in Aruba.
Old Apr 8, 2008 | 01:52 PM
  #33
laraul43's Avatar
not to keep asking the same question but, I did a compresion test on my 03 evo and it read 130, 125, 70, 130 I know within 20% is ok but this is substansially more what is causing this?
Old Apr 8, 2008 | 03:01 PM
  #34
RoadSpike's Avatar
Wow thats crazy low compression numbers did you just do like one spin? Make sure you've pulled all the plugs and connected the battery to a charger for more accurate results. And do you have cams?
Crank it for 3-4 pops in the gauge then stop.
MrEvo9Mong
Mar 17, 2017 08:11 AM
robh
16
Mar 12, 2017 12:10 PM
lostsoulsevo
28
Feb 9, 2017 05:52 PM
AKB_EVO
Dec 12, 2016 08:02 PM
gizevo
15
Sep 3, 2015 09:46 AM
