Replaced Plugs now a stutter
Old Sep 17, 2006 | 06:30 AM
newbieEVO8's Avatar
I replaced my plugs with some autolite copper core plugs.
Gapped them to .25 and now with partial throttle I get a stutter from around 3.5k rpm to just over 4k rpm.
Any ideas?
I double check the connections everything looks good there.
Old Sep 17, 2006 | 07:15 AM
Gary C's Avatar
Post
I would first reinstall the old plugs and see if the problem persists.
Old Sep 17, 2006 | 07:19 AM
brokeazzlos's Avatar
throw away those plugs and get some ngk's
mitsubishi cars are notorious for misfiring on bosh, autolite, and other plugs
get ngk or denso
Old Sep 17, 2006 | 07:41 AM
revvin9k's Avatar
get ngk or denso
+1, same thing happened to me even running the NGK's. Re check your gaps and/or replace the plugs.
Old Sep 17, 2006 | 07:43 AM
scottatyamaha's Avatar
Get rid of the autolites.....sorry you wasted your money
Old Sep 17, 2006 | 08:06 AM
newbieEVO8's Avatar
No problem on the money cause they were like a 1$ a piece.
I will go today and get some denso's.
Thanks guys that is what I was thinking but I guess I just needed confirmation from someone else.
Old Sep 17, 2006 | 03:38 PM
newbieEVO8's Avatar
Ok so I learned to not buy plugs from Walmart.
I went and got some NGK 7e IX's.
They came gapped at .28 so I left them at that and installed them.
So far they are not causing any problems.
Old Sep 17, 2006 | 05:36 PM
xspsi4's Avatar
What heat range where they?
Old Sep 17, 2006 | 07:44 PM
Glad you got the NGK's i was about to tell you not to get the Denso's also. i am running those plugs also and I love them.
Old Sep 17, 2006 | 09:56 PM
Warrtalon's Avatar
IX means Iridium, so I'm glad you didn't try to re-gap them, because you're not supposed to mess with the gap on Iridiums...
rage mang
Feb 4, 2017 06:58 PM
Danial81
Lancer Troubleshooting
Sep 8, 2016 09:31 PM
butte
Jul 2, 2016 03:54 AM
10isace
Nov 14, 2012 10:13 AM
bchappy
Oct 12, 2008 02:30 PM
