Update on TurboTrix HP61 turbo...
Well, changed out the housing with a .82 a/r and upgraded my BOV to a Tial to handle the pressure.
Went to TTR Friday for a retune and check up on the power numbers. Results were way better than the first time around with the .63 hotside and weak leaky BOV.
Car feels awesome now and pulls hard as hell up top
I can almost guarantee that run was on race gas. 50 trim on race gas will hit peak boost around 5k or a lil later, on pump gas 4500 or so is usual on a 2.0.
Scorke
Scorke
Here is the 50 trim graphs for comparison, sorry this one is in MPH but you can get a general idea. The HP61 is def laggier, but its not as bad as you'd think driving the car its very comfortable. Just don't expect to have anything below 3k like you would with the stock turbo. Neither the 50 nor hp61 have anything below 3k.
Originally Posted by scorke
I can almost guarantee that ru nwas on pump gas. 50 trim on race gas will hit peak boost around 5k or a lil later, on pump gas 4500 or so is usual on a 2.0.
Scorke
Scorke
If you all will read even 5 more lines into my sig, you'll see its pump + meth.
Haha i meant race gas. THC does have its downsides....... Were my guesses for full boost on pump/race close atleast?
Also do you think the 50 trim would be faster at the track with the greater tq numbers?
Scorke
Scorke
Boosted- The 50 trim makes more whp on pump gas than any other turbo for the most part. You might find a GT35R or some other BIGG turbo making bigger numbers but at the expense of a lot of tq. Dollar for dollar on pump gas the best choices are a 20g, 3076, and 50 trim in the order from worst to best in that size range, on race gas the 3076 tends to put out very similar hp numbers but much greater tq numbers.
Scorke
Scorke
Scorke
Scorke
Your guesses were pretty much right on, I"ll have to go back and look at some of my 50 trim logs, but I had a full 28psi(on meth of course) at about 4700 or so I think.
Honestly I'm not sure which would be faster, I would hope that the HP61 would simply b/c it costs more and is bigger
But then again on stock block, I think the 50 trim is the best ultimate turbo. Anything over 500whp and your looking at a ticking timebomb, and the 50trim puts out 500 with ease and an awesome powerband.Realistically with the 50 trims powerband, I think it would beat the 61 down the track...but the 61 is going to have a higher trap....I dunno it would be a close race IMO.
Originally Posted by KOEvo
Wow, full boost at 6500 rpm's, that sucks.
508whp 448wtq TTR 50 trim, 93/alky. VS 533whp 417wtq TTR HP61 93/alky.
not sure is it worth to traded 31wtq for 25whp plus slower spools by switching to the HP61... do u feel any difference between the 2?
