Getting some Ratterling from HEAD!!!!
Old Sep 21, 2006 | 10:28 PM
JMB8606's Avatar
Im getting some knocking or some rattling form the head and what to get some ideas of the cause. Its comming form the head for sure by the Oil cap #1,#2 pistion, or intake mainfold. Would a bad lifter or rocker cause this? the noise, its just a little louder than the normal ticking the 4g63's make. Any ideas would be great.
Old Sep 21, 2006 | 10:30 PM
MiamiEvo8's Avatar
what oil filter you using?
Old Sep 21, 2006 | 10:32 PM
Alfred@TTech's Avatar
The EVO oil pressure at idle is rather low. The manual states that 10psi at idle is fine. If you have cams, it may cause some lifter tapping. If its excessive loud, look into it.
Alfred
Old Sep 21, 2006 | 10:37 PM
MiamiEvo8's Avatar
I heard and had the problem after I used a different oil filter other then factory. I changed back to factory and sounds fine now. Maybe a myth but alot of people told me I might get lifter noise if I used a filter other then mitsu and thats what I got for using a purolator filter.
Old Sep 21, 2006 | 10:51 PM
JMB8606's Avatar
Was the noise coming for the pistion 1 or 2 or near the oil filter. I do have a non-mitu oil filter on there now that a shop installed.
Old Sep 21, 2006 | 11:06 PM
MiamiEvo8's Avatar
I don't know I just knew it was comming from the lifters. It was told to me that I might get this noise before I changed filters but I figure what the hell why would they make it if it would be a problem., Wrong. I drove to dealer after filling with oil, bought the OEM filter, went back home, added some oil in the filter, changed it and wa-la no more noise. Up to you what you do next but OEM filter cost just $8 more for piece of mind.
Old Sep 21, 2006 | 11:19 PM
icedomin8r's Avatar
Sometimes I get a little rattled from head too......
Old Sep 22, 2006 | 02:16 AM
ONRAILS's Avatar
check your oil..
2$ bet on spun bearing..
Does it to it all the time? and has it progressively gotten worse?
I would NOT drive your car like this.
Old Sep 22, 2006 | 05:51 AM
C6C6CH3vo's Avatar
Originally Posted by ONRAILS
check your oil..
Wow, I'm glad you don't work in the medical field - kidding. Check your oil filer fiber and oil to make sure though
Old Sep 22, 2006 | 06:45 AM
JMB8606's Avatar
Im a 100% sure its not a bearing. The motor is a fresly built 2.3 with 230 miles oil level is good. Im almsot sure its a lifter now. The oil has only been changed 1 time and the oil filter is an off brand.
RA2013
Dec 11, 2013 09:44 AM
Show Off
Southeast Region
13
Apr 2, 2008 11:31 AM
goucho
Nov 19, 2007 01:34 PM
evo8forme
Aug 19, 2006 05:14 AM
leary123
Jul 4, 2006 09:17 AM
