Stock IX with boost controller??
Old Sep 29, 2006 | 07:45 AM
Sschmuve1's Avatar
I searched...but nuthin. Please excuse the newb question.
How much hp should I expect fom installing a manual boost controller? Max gain and peak power. The max I should set it is 21Psi (93oct) right? Thanks.
Old Sep 29, 2006 | 07:51 AM
deffro's Avatar
Not a whole lot. You will be able to hold boost better though.
Old Sep 29, 2006 | 07:52 AM
Rnm's Avatar
Rnm
Get a turboback while your at it and then flash it.
Old Sep 29, 2006 | 08:03 AM
DanJ's Avatar
I would say maybe 10whp.
Old Sep 29, 2006 | 02:19 PM
Sschmuve1's Avatar
10 hp peak, but wouldn't it be a greater increase higher in the powerband where the boost taper is eliminated? I mean, if let's say at 5300 rpm the stock pressure tapered down to 17, but the B.C maintained it at 19psi. Wouldn't that amout to around 20 hp gained?
Old Sep 29, 2006 | 02:36 PM
Rnm's Avatar
Rnm
IX's are known to taper moreso than the VIII's thanks to MIVEC, but they still make more power than them. Even with a MBC in place, your going to taper although it will be more gradual than stock.
Old Sep 29, 2006 | 11:08 PM
BigBallin's Avatar
i would expect more than 10 whp goin to two pound of boost. i would say20 to 25. but no one really know unless someone has a dyno.
whatever210
Jul 23, 2014 11:38 AM
mannerism
Jun 2, 2009 03:16 PM
paranoidpants
36
Jun 20, 2007 02:15 PM
oreficeraffaele
Jan 28, 2007 01:47 AM
ecmotorsports
25
Aug 31, 2006 09:49 PM
