CEL Codes P69 and P113
Old Sep 30, 2006 | 06:50 PM
Redline06's Avatar
Exclamation CEL Codes P69 and P113
I've been looking for help everywhere.. I got the following codes immediately after putting on my Buschur Mass Air Pipe Kit w ith Filter:
P0113 Intake Air Temperature Circuit High Input
P0069 Currently Unknown<---wtf..???
Can anyone help me gettting this fixed.. this is my only mod..? you guys think my MAF is done for.. any help is good.. I did everything right except using that K&N Breather filter..! Instead I used that APC Intimidator Breather Filter and it fit just right.. I hope jst cuz i didn't use K&N my **** if F*** Up.. well thx in advance guys..
Old Oct 1, 2006 | 12:03 PM
3SgteGuru's Avatar
P0069 Manifold Absolute Pressure - Barometric Pressure Correlation.
P0113 Intake Air Temperature [IAT] Sensor Circuit High Voltage
I think Those are Related but i got to do some Reasearch to find out. Will update Later.
Old Oct 1, 2006 | 12:48 PM
gsrboi80's Avatar
sounds like you didnt plug the MAF sensor bak in or damaged it in some way. Go over everything agian
Old Jan 17, 2007 | 12:39 PM
mdacko's Avatar
bumping this up because i'm having the exact same issue as this guy was, except i'm getting these 2 codes:
P0113 Intake Air Temp Sensor High
P2228 Baro Press. low
triple checked that everything was tightened down, maf sensor is plugged in all teh way. i even put the stock intake tube on and left the bushur filter and still getting CEL. getting ready to throw this thing out the window, but would like to possibly try to solve the issue first
thanks,
Michelle
Old Jan 17, 2007 | 01:12 PM
RoadSpike's Avatar
Some images for thought
Sounds like the IAT sensor is busted and the barometer may be diconnected.
Attached Thumbnails CEL Codes P69 and P113-1.jpg   CEL Codes P69 and P113-2.jpg
Old Jan 17, 2007 | 03:04 PM
Redline06's Avatar
Take it in to the dealership.. that what I did.. the EGT line on my had a cut an it was giving an incorrect reading.. pretty much if everything is connected right.. next step is to run the line for cuts..
Old Mar 18, 2013 | 12:10 PM
kyoo's Avatar
bump for this.. i've got p0069 and p0122 lol
Tibu
Lancer Troubleshooting
May 15, 2017 12:35 PM
BrianBarnes
Sep 26, 2016 07:55 AM
MitsuSkot
Apr 9, 2016 05:39 PM
MaxKanisha
39
Oct 2, 2007 03:56 PM
KMcW
23
Jun 29, 2006 11:51 AM
