engine blew!
Old Oct 2, 2006 | 08:22 AM
dwcdds93's Avatar
Dealer said they think an injector locked up and caused the backfire. Also blew off the induction hose. They are in contact with Mit. to get permission to replace all injectors. Thanks for the quick replies, I am relieved it is not something worse.
Old Oct 2, 2006 | 08:23 AM
dwcdds93's Avatar
Luckily still under warranty, everything covered!
Old Oct 2, 2006 | 08:26 AM
joeymia's Avatar
lol your car probally had a really bad boost leak causing you to run rich enough to misfire. When you get your back from the dealer I suggest replacing all the clamps with tbolts.
Old Oct 2, 2006 | 08:27 AM
SilverEvo8owner's Avatar
That is the most rediculous thing i have ever heard.
Backfire into the intercooler pipe causing it to blow?
Oh well, hope you get a new set of injectors
Old Oct 2, 2006 | 08:32 AM
TTP Engineering's Avatar
And we all know, the dealer is the expert.
They are wasting their ****ing time and Mitsu's money on their goose chase.
Put your IC hose back on and get on the road.
Old Oct 2, 2006 | 09:11 AM
BlueDemon's Avatar
ahhh come on, first they clean the injectors and now they decided it is best to replace them all, riighhttt!!!. What if you still get the misfire code....are they going to give you a new set of plugs, coils, starter....free oil change to keep your mouth shut...
Old Oct 2, 2006 | 09:15 AM
jqturbo's Avatar
Originally Posted by BlueDemon
...What if you still get the misfire code...
Oh, he will! It's inevitable once you begin to get it.
Old Oct 2, 2006 | 09:34 AM
dwcdds93's Avatar
The misfire code has been different lately. It started as a misfire at like 3700rpms. That was corrected with the reprogram. Now it has been misfiring at idle, and 0mph. They said they thought it was the injectors, but who knows at this point.
Old Oct 2, 2006 | 09:49 AM
Ev0ikon's Avatar
If you or your dealer can get this fixed, you will be the first to do so. You dealer can make a LOAD of money if they do. Good luck
FWIW, I get this P0300 code too just sitting at idle. There is no other symtom or drivability problem associated with this code on my car at all. Just a computer glitch I assume.
Old Oct 2, 2006 | 09:53 AM
dwcdds93's Avatar
so do you just live with the service engine soon light on all the time? that really bothers me.
Old Oct 2, 2006 | 10:07 AM
Ev0ikon's Avatar
Yes. I learned to live with it.
But I also have something (ECU+ and PalmPilot) attached to the ODB port that I can read off it rather quickly.
If you don't want that SES light on all the time you could buy a "creader" and leave it attached to your ODB port and set it to automatically erase that code as soon as it pop up.
Otherwise you have to buy a new Evo and hope that it doesn't have this glitch.
Old Oct 2, 2006 | 10:10 AM
Ev0ikon's Avatar
But on a serious note, you COULD use that as an excuse to make the dealer buy it back.
You could do that now or just wait until the dealer have exhausted their money and energy trying to troubleshoot this issue.
Old Oct 2, 2006 | 10:24 AM
jqturbo's Avatar
Yes...it is a nuisance, and those w/out the creader get annoyed as well.
Old Oct 2, 2006 | 10:30 AM
DynoFlash's Avatar
Originally Posted by TTP Engineering
newbies
Everyone was a newbie at some point and I think its better that the member post here to get a informative answer than continue with misinformation and not knowing
You both have phones and PMs... use them...
-Zeus-
Old Oct 2, 2006 | 10:38 AM
Ralph's Avatar
