4g63 block differences
Old Oct 9, 2006 | 05:40 AM
1HIPCAT's Avatar
Hi, All
I'm fairly new to dsm engines and just had a few questions. I'm basically looking for a spare block for my 9. I'm going to get a stroker kit, but I don't want to pull my engine until I have a finished stroked short block to replace it. So my questions are...
What are the generations of the 4g63 and which ones are compatible with a mivec head?
Where can I locate said block either new (other then the dealer) or used?
I hope I didn't irritate any one but I didn't find anything useful with the search.
Thanks for looking!
Old Oct 9, 2006 | 11:33 AM
Tim@AMSperformance's Avatar
the only block that will work with a mivec head is a block from a mivec head engine
Old Oct 10, 2006 | 05:49 AM
1HIPCAT's Avatar
Thanks for responding! The dealer told me something different, that the head could be changed throughout the last generation of engines. Some I have talked to have mentioned taping oil ports. And I am familiar with the first gen with the tranny on the right side of the engine. So I'm aware that a 1st gen won't work.
Do you know why the mivec head won't work on say an evo VIII block. I have bean building import race engines for about 12 years so you won't confuse me. Thanks Again!
Old Oct 12, 2006 | 06:38 AM
japspec4g63's Avatar
if en evo VIII block would work, would an evo V one work?
if so, I have an evo V block for sale
Old Oct 12, 2006 | 05:52 PM
1HIPCAT's Avatar
I wish I knew I'll try and find out. How much are you wanting and what year is it?
Old Oct 12, 2006 | 08:22 PM
its from a 98 evo V gsr. if the VIII bottomr end will work, then the V will too.
Old Oct 12, 2006 | 08:32 PM
SaOrlando's Avatar
at one point i knew someone who had a whole ix engine sitting around...i wont mention names in public. pm me if interested, and ill let you know who it was
Old Oct 12, 2006 | 08:45 PM
an evo 5 is prettty much the same bottom motor as the evo 8 mabye the waterpump and some other minor things are different.
saorland please pm me someinfo on the evo 9 motor im also lookig for a evo 9 engine harness
Old Oct 12, 2006 | 11:57 PM
NDgsx's Avatar
The later 4Gxx engines have additional oil drain holes relative to the early blocks, I am not sure what year that changed for the evo specifically though.
Old Oct 13, 2006 | 06:14 AM
1HIPCAT's Avatar
Now I'm really confused so mivec on the evo only controls timing and not duration?
http://en.wikipedia.org/wiki/MIVEC
Then it's very possible the blocks are the same. If that's the case then all these 2nd gen parts I see all over will work.
Old Oct 14, 2006 | 02:40 AM
Don evo5's Avatar
I think the mivec system works on the cam gear itself and advances timing that way if you are going to use an evo 5 6 7 block the water pump is different and you will have to get one to suit. Why not ditch the mivec altogether
Old Nov 21, 2006 | 01:37 AM
hekatombe's Avatar
JAPSPEC4G63, I'm looking for a 4g63 block.
Contact me on hekatombe@hotmail.com please
Old Dec 5, 2006 | 02:30 PM
darqnez's Avatar
ix block does indeed have different oil cooling setup over the viii so ix engine only would be safe
Old Jan 10, 2007 | 07:14 PM
kosmoz's Avatar
where are u at?
Old Jan 27, 2007 | 11:24 PM
trinydex's Avatar
supposedly the evo v and vi blocks have larger cooling passages than the vii viii nad ix blocks
