forge wga....
forge wga....
ive searched and read around but still no answers. i installed my forge wga and adjusted the best i could but i noticed that at idle i hear a ratling sound from the exhaust under the car, it was the wastegate flapper..... and its worse (annoying loud) when the engine revs down. now its adjusted tighter and the sound has stopped but now i have the ebc turned all the way down and still hit around 19psi(seems a lil unsafe turned all the way down right?). do i need a lighter spring or does anybody else have any experience with this that can help me out??? thanx
Originally Posted by idriveaevo
any ideas on the adjustment or why the wg rattles???
Does the actuator have a nut adjustment too correct this?
The intent of having adjustment is to tighten the turn buckle and add pre-load/tension to the spring inside the unit, thereby increasing boost output.
We build the Evo actuators with a spring rated to the boost levels that most owners typically run. If you're concerned about how high the unit is set to boost, other (lower tension) springs are available upon request to be built into a unit or they're also available individually for $16 each.
Green - 5-10 PSI
Yellow - 9-15 PSI
Blue - 14-18 PSI
Red - 19-24 PSI (this is what is installed in your unit)
Green - 5-10 PSI
Yellow - 9-15 PSI
Blue - 14-18 PSI
Green - 5-10 PSI
Yellow - 9-15 PSI
Blue - 14-18 PSI
Green - 5-10 PSI
Yellow - 9-15 PSI
Blue - 14-18 PSI
