LSD Oil Help
Old Oct 16, 2006 | 05:40 PM
Jeffs2006EVOIX's Avatar
LSD Oil Help
Ok all, does anyone know for fact what the the equivalent gear oil is for the 9? I have been wanting to try to upgrade the gear oils but the manual says 75-90 can be used in the gearbox, but "Mitsubishi LSD Oil" or equivalent in the front and rear difs. So what is the Equivalent? I have narrowed down my choices on personal preferecne to Royal Purple or Redline, both have the hypoid gear oil additives for limited slip already mixed in.....So whats the Equivalent.....Thanks For your time all.......
Got Freedom?
Thank You to all our Military and their families......
Old Oct 17, 2006 | 08:56 AM
19psi's Avatar
I wouldnt put anything other than stock fluids in the transfer case and rear diff.
But...search button is your friend bud.
There has been numerous threads about this.
Old Oct 17, 2006 | 01:47 PM
The Post
Your right in the transfer case I am and will when needed use the Mits fluid, but I am talking about the front and rear axles not the transfer case.
Old Oct 17, 2006 | 03:04 PM
19psi's Avatar
You might wanna read your question again.
I see nothing that says anything about axles.
I see LSD and front & rear diffs.
Old Oct 17, 2006 | 03:14 PM
06redMR's Avatar
i took my car to southcoast mitsu and the guy recommended using a thicker redline fluid in the t-case so i did. seems fine to me
Old Oct 17, 2006 | 03:53 PM
JoizeeX's Avatar
Got Freedom?
any reasons for "upgrading" the oils though? i mean, most likely, you won't even notice the difference, and the factory oils make the parts last a very long time, so why would you swap? i'm just curious. if you're going to track the car at autox or road course or rally, that might make sense then.
laksman91
71
Dec 20, 2014 06:51 PM
Golfa
Feb 4, 2013 10:15 AM
Nex1
Toronto Lancer Club
Jun 3, 2010 10:10 AM
rio-evo
Feb 23, 2008 12:36 PM
SpdElemts
25
Nov 19, 2007 04:08 PM
