Front end problem
Old Oct 17, 2006 | 07:13 PM
05silevo's Avatar
Front end problem
Ok I get a popping sound from my front end when I turn to the right. I jacked up the car and turned the wheel and couldn't hear anything. It only does it while the car is moving. It also is worse If I hit bumps while turning right. I checked all the bolts to the strut and all the bolts on that side. Any suggestions? Thanks
Old Oct 17, 2006 | 07:17 PM
kdwg927's Avatar
The two most likely suspects would obviously be a bad strut, and the other one would be a motor mount. On my old dsm, it used to pop alot and after replacing the struts (agx ftw!) I finally found that is my motor mount.
Old Oct 17, 2006 | 07:27 PM
RevMoto's Avatar
Could be your joint on your control arm that might be loose. My buddy's sti had that problem. That was it.
Old Oct 17, 2006 | 07:34 PM
05silevo's Avatar
I will check those things
Old Oct 17, 2006 | 08:16 PM
05silevo's Avatar
checked the motor mounts and those are all good
Old Oct 17, 2006 | 08:39 PM
dubbleugly01's Avatar
CV joint or wheel bearing. Most likely on the driver side.
Bad strut or motor mount? Why would there be a popping sound only when turning right if these were the cause?
Old Oct 17, 2006 | 08:41 PM
RoadSpike's Avatar
+1
had an old 4x4 toyota pickup do that exact same thing
Old Oct 17, 2006 | 08:57 PM
NYEVO8's Avatar
you sure its not that damn front end clunk that most early evos had, not that yours is early but you never know, just giving an idea. because mine did it also when turning right, it was the spring popping out of place then going back in
mine had that noise, bought some the MR setup from someone on this board, and been noise free since then.
Old Oct 19, 2006 | 09:39 PM
05silevo's Avatar
Taken it the dealer they can figure it out
Old Jul 26, 2008 | 10:50 AM
20austin08's Avatar
What did they say ended up being wrong with it?
