Which Intake Mani
Originally Posted by wspy
So with the entire kit installed is there enough space to mount a direct port nitros fogger system on the intake runners i.e. space between the fuel rail and the surge tank - a fogger on each runner?
Hi Geoff, that is a beautiful manifold. Is the reason the stacks protrude into the plenum because of desire to maintain tuned length specific band and packaging requirements conflicting? Is it the same case for your Honda intake manifolds too? Have you tried flush plenum to stack transitions? On your Honda intake manifold, the plenum overhang on the last runner is a lot shorter than on the Evo manifold. Again, is this due to packaging? The Honda manifold looks like it would even distribution with slightly more overhang.
It will fit the IX and it does have an option for the MAP sensor bung to be able to use the stock fuel system. for pricing, please call the shop at 602-437-2101 or email Henry (sales manager) at henry@full-race.com
thanks
thanks
Originally Posted by SWOLN
Any chance this will fit the IX, and what is the cost?
Thanks
Thanks
i agree its a lot, but if you saw this TB its easy to understand.
Ask anyone with experience using an accufab/wilsons/holley/any other US TB not intended for boost -- they always have a vacuum/boost leak and obviously dont allow you to use the stock TPS.
dubbleugly01
Oct 5, 2006 09:32 PM
