loud whining coming from front of car???
Old Oct 19, 2006 | 10:41 AM
05evoGSR's Avatar
Originally Posted by gsrboi80
The whine at cruise is your TC. You can try changing your fluids. Only use Diaqueen dont listen to anyone there is no reason to put anything else in you TC or rear diff.
Oh and Syncromesh in the tranny is a definate upgrade shifts way nicer I swear by the stuff as does alot of the members on this site. Shep and TRE both recomend this and BG Syncroshift in the tranny exclusively. The syncromesh is cheaper but you have to change it out a little sooner
I just did some reading on "whining noise" and it seems like it is the TC. Now it just started making the noise last week, its not horribly loud like some have described but it is def noticible in 5th gear at cruise. Should i be able to make i though the winter without sending it off to Shep? Also if i do get it rebuilt by Shep, should i have to worry about this happening again or will it basically be indestructible? I mean i dont drop the clutch when i launch, i shift kind of hard but no power shifting or anything. No idea why the TC would be going, i kno people that beat on their car a lot worse than me and no TC problems
Old Oct 19, 2006 | 10:43 AM
05evoGSR's Avatar
Originally Posted by smokedmustang
I say the TC is going bye bye. Type in "tornado siren" in the search bar above, and see if it describes what you are talking about. good luck.
Thanks, i checked it out and i got some good info. Looks like Shep will be hearing from me soon lol. BTW how much is it for a rebuild from Shep and how do you like your TC now?
Old Oct 19, 2006 | 10:44 AM
gsrboi80's Avatar
It happens AWD cars are not relly meant to be launched at all. But yea after a rebuild it will be damm near bomb proof
Old Oct 19, 2006 | 10:52 AM
Smike's Avatar
Originally Posted by 05evoGSR
umm never...the car has 20k miles on it. I was thinking about upgrading the trans fluid to Pennzoil synchromesh...should i upgrade the TC fluid also? If so what would i use for the TC?
Yep sounds like a TC. Only Mitsu fluid for the TC.
http://www.teamrip.com/index.html
http://www.sheptrans.com/stages.php?vid=evo
And I would not use Pennzoil - it will work, but its not that great, and you'll have to change it often (like every 5k). Search BG I or BG II for trans fluid. BR Racing has BG II for 11 a qt, takes 3 - so $33.
Old Oct 19, 2006 | 11:05 AM
EVOLVEU's Avatar
its like $1600 for the tranny (and xfer case?, not sure). sorry to hear your misfortune.
Old Oct 19, 2006 | 11:20 AM
05evoGSR's Avatar
Well first i am going to change the fluids in the TC, trans and the diffs. Prob BG II in the trans and Diaqueen in the diffs and TC and see how that goes. Im not going to be beating on my car over the winter months, i just hope nothing goes on me before the spring. Do our trannys usually go also or is it the TC that is the weak point after a clutch upgrade?
Old Oct 19, 2006 | 11:26 AM
gsrboi80's Avatar
I can change my tranny fluid 3 times with Syncromesh for what it will cost me to change it once with Syncrshift. (Parts Account Rocks ***). Thas one of the main reasons plus it feels the same in there BG lasts a little longer thats all
Old Oct 19, 2006 | 11:36 AM
Smike's Avatar
Pennzoil - about 6 a qt - so $18 for 3. Lasts 5k. Maybe 1-2 track days.
BG II - $33. Lasts about 15k normal use or 4-5 track days.
But normal use-wise that Pennzoil will cost you $54 for 15k v. $33 for BG. But hey, its your car and money.
Old Oct 19, 2006 | 11:41 AM
05evoGSR's Avatar
Im not to worried about weather i used Pennzoil or BG in the trans, i know either will do fine just have to change the Pennzoil more often but its cheaper. The TC situation is whats got me worried. I just dropped about 3500-4k into my car between parts, labor and tuning and now this. I havent saved a dollar in the past 3 months lol. Owning an evo that you like to race once in a while and go out to the bar 5 nights a week keep your pockets pretty empty lol
06redMR's Avatar
whats wrong with redline in the Tcase? i went to southcoast mitsubishi and the guy over there recommended a thicker weight redline oil in the tcase over the stock fluid and stock fluid in everything else unless i request BG for the tranny.... this was at a mitsu dealership. been driving it since saturday and it seems fine to me
SyncdLancer
Sep 29, 2016 04:39 PM
TurboIX
25
Nov 1, 2010 07:52 PM
R/TErnie
36
Dec 13, 2009 12:19 PM
diezilnj
Jan 12, 2008 10:25 PM
TeStUdO
14
Jun 30, 2006 08:11 AM
