Is there any intake does not require a tune?
Old Oct 24, 2006 | 08:52 PM
  #31
Doogie Howser's Avatar
stock
Old Oct 24, 2006 | 10:20 PM
  #32
Bosshog's Avatar
Originally Posted by SlowCar
kill 2 birds with one stone, no tune, loud turbo/bov noise
this is actually what I thought about doing for a while. do you get the tipical intake sound when you do this - how does the sound compare to say hks rs intake?
Old Oct 24, 2006 | 10:30 PM
  #33
xballsport's Avatar
Im also intrested in doing this. Does it affect idle? is the bov get alot louder? or a little bit more noticable.?
Old Oct 24, 2006 | 10:41 PM
  #34
DruMMinStUd06's Avatar
Because you can sell it and get parts that actually help the car. If all you car about is hearing the turbo suck air in and the BOV blow off, then your Evo is wasted. If your BOV is not the Forge RS, then you have the wrong one (noticing a theme here). The direct replacement one is not good for the Evo, sorry. Hopefully, you have the shiny Forge RS with the adjustment knob on top.
Talk about ignorance...his reasons for purchasing a car don't have to match yours.
Old Oct 25, 2006 | 06:03 AM
  #35
SlowCar's Avatar
the hks being an open element, is definately much louder
hks -> stock box with big hole on top lid - > stock box w/ no hole (loud to soft)
tried both, when back to stock box eventually.
Old Oct 25, 2006 | 06:06 AM
  #36
SlowCar's Avatar
does not affect anything. bov and turbo suction noise is definitely much louder
its free, you already got it. just have to spend 30mins to cut the hole out or put it on a mill like what i did
Old Oct 25, 2006 | 06:16 AM
  #37
andyktlee's Avatar
Pocket Mo
Buschur cone for the open filter route.
Apex-I isn't causing any problems for members that have it as well.
Would I purchase an intake with no tune? Kinda defeats the purpose except you get sound. The only reason I purchased the Apex-I intake is being it's zero maintenance. I like to get lazy when possible.
Old Oct 25, 2006 | 06:48 AM
  #38
boostinjuice's Avatar
Stock airbox will hold 400 whp without any problems
Old Oct 25, 2006 | 06:53 AM
  #39
Does the hks rs intake have a maf adapter?
Old Oct 25, 2006 | 07:23 AM
  #40
jqturbo's Avatar
Originally Posted by whitey4d
My car ran fine with an AEM intake on the car with out a flash for 4-5 months...
Ditto! I purchased my car with an exhaust and the AEM intake/filter on the car already, and it ran fine for 8 months til I finally got more mods and a flash/tune. I read all these threads about hating on intakes and just using the stock cause it's good enough. Sure, that might hold true, but there are some intakes out there obviously that are just as good as well...as me and whitey4d proved.
Old Oct 25, 2006 | 07:55 AM
  #41
SlowCar's Avatar
my friend, if only you could datalog
https://www.evolutionm.net/forums/at...chmentid=72429 – stock
https://www.evolutionm.net/forums/at...chmentid=72430 – open element
Old Oct 25, 2006 | 08:00 AM
  #42
Rexpeed's Avatar
k&n drop in filter works good
Old Oct 25, 2006 | 08:02 AM
  #43
Spec'd's Avatar
r0ck3r ,
I see you're at it again.
Old Oct 25, 2006 | 08:08 AM
  #44
jqturbo's Avatar
Well, that graph doesn't show how good the car was running with no idle effects or noticeable loss of power. Maybe the car wasn't running to it's full potential, but my point is, with the AEM intake it was noticeable w/out running tests.
Old Oct 25, 2006 | 08:12 AM
  #45
saiyanzzrage's Avatar
the stock airbox doesnt require a tune
