Those with Invidia O2 housing...questions
Old Oct 29, 2006 | 09:16 PM
MitsuJoe's Avatar
I have a Buschur DP that I have been contemplating how to make fit. Rather than do this I am interested in knowing what DP you have with your Invidia O2 housing. Basicly if I can get away with getting another DP so I don't have to modify this one it would be much preferred.
Also what did you do to make the O2 sensor wires longer? Good to know!
Old Oct 30, 2006 | 08:32 AM
dafoe69's Avatar
I have the Invidia housing and Buschur DP. Chopped stock flange off stock DP and had it welded to the Buschur DP. Didn't lenghten the O2 sensor, it's stretched but no problems yet.
Old Oct 30, 2006 | 09:53 AM
RallySport Direct's Avatar
Silver Sponsor
On my personal car I am using the TurboXS downpipe(different sized donut) I was able to easily modify my donut to accept the Invidia Housing. I have not done a install on a flat flanged DP system yet.
O2 sensor wire stretched and heat shielded here.
Old Oct 30, 2006 | 12:21 PM
MitsuJoe's Avatar
That is a solution of sorts. A little more than I wanted to do to the Buschur DP. I was hoping just to port out the opening on the flange to make it a full 3", do you think this would work?
Old Oct 30, 2006 | 01:05 PM
dafoe69's Avatar
You could try porting it and if that doesn't work just chop and weld.
Old Oct 30, 2006 | 01:08 PM
moreryce's Avatar
i have the Invidia downpipe.. but im pissed cuz it rubs on my oil pan and im sure thats why im getting such high oil temps at the track...
Old Oct 30, 2006 | 01:10 PM
MitsuJoe's Avatar
I was curious if the Invidia DP was any good. Do you have the Invidia O2 housing and the Invidia DP?
Old Oct 30, 2006 | 01:13 PM
o.e.boost's Avatar
i belive the individa dp is pretty good...clears acd and tc as well as a true 3in opening...not to sure but i think it comes with an adapter and hardware to make it fit stock o2 and the individa o2 housings...
Old Oct 30, 2006 | 05:36 PM
MitsuJoe's Avatar
I can't be sure that I would be able to mix the Buschur system I have with the Invidia DP/testpipe. Hard to say.
I think I might have a spare EVO stock DP so I can use that if I want to cut and modify to put on the Buschur unit.
Old Nov 8, 2006 | 11:01 AM
JSC Speed's Avatar
Former Vendor
I've got the Invidia on my 05 -- clears everything very well, I did have to space the bars, but only w/ 1 or 2 washers. Fitment is very good around the TC.
Old Nov 8, 2006 | 11:18 AM
kimletrim's Avatar
Registered User
Here's a solution to your second concern regarding the O2 sensor. This is what I did on my car.
The O2 sensor is on the other side of the engine and so is the wiring!
The O2 sensor wiring and harness are between the valve cover and the upper intercooler pipe.
It took about 30 minutes, but its well worth it.
Old Nov 8, 2006 | 01:05 PM
MitsuJoe's Avatar
So is the wire that looks like it is hanging off from your manifold for EGT?
So did you extend the wiring or did you pull it out from the loom and reroute it?
Old Nov 17, 2006 | 06:56 AM
incog6's Avatar
I had the same exact setup you have. I bought an invidia o2 and a buschur dp only to find out that they would not match. So, the best fix was to buy an invidia 3" dp.
kenikh
Jun 15, 2009 04:43 PM
LoveBoost
29
Jan 30, 2008 10:19 AM
WarmPepsi
Feb 26, 2007 10:45 AM
geevolution
Dec 27, 2006 08:25 AM
evilevo2006
Jun 16, 2006 01:19 PM
