Trouble engaging reverse
Old Oct 30, 2006 | 02:48 PM
manny85382's Avatar
I just installed a exedy twin plate heavy duty disk yesterday and when I am at a dead stop I have trble putting the car in to gear mainly reverse. But when the car is roling it shifts as smooth as butter into any gear 1-5. What could be wrong do I need to adjust the clutch pedal? Or is this normal for a heavy duty clutch? When the car is turned off it will go into reverse with no problem, but when turned on I have to give it a good push.
Thanks
Manny
Old Oct 30, 2006 | 02:51 PM
RoadSpike's Avatar
probably the teeth of the gear not lined up with the syncro. If you want the way i've always got mine into gear when it wont line up was to put it in 3rd then into reverse.
Its happend to me on my stock car a couple of times.
Old Oct 30, 2006 | 02:53 PM
EVIL_EVO_VIII's Avatar
Same thing started when i just got my new clutch in... Put it in 5th gear and then try reverse, it should work
Old Oct 30, 2006 | 03:04 PM
hondafan's Avatar
usually it is a good idea to adjust the pedal anyway after installing a new clutch even though i don't think yours is far off or you'd have lockout issues. TRE reccommends putting all four wheels off the ground and adjusting until the wheels start to turn when the pedal is 3" off the floor.
Old Oct 30, 2006 | 03:05 PM
EvoAnthony's Avatar
Adjust the pedal and you'll be good!
Old Oct 30, 2006 | 03:07 PM
scottatyamaha's Avatar
Even after i adjusted my pedal abunch and finally got things to shift better I still have to put the car into first gear and then go into reverse.
Old Oct 30, 2006 | 07:27 PM
manny85382's Avatar
Ill try adjusting the clutch, my installer lives 2 hours away but he checked the clutch pedal and felt it didnt need adjusting. I talke to him and he agrees that the clutch pedal might need some adjusting. But when Im driving around it shifts super smooth I have not had a problem shifting since it has been installed a little over 24 hours ago.
Thanks for help guys.
Manny
Old Oct 30, 2006 | 07:39 PM
Silk's Avatar
I have the same problem even on my stock clutch. I just let out the clutch so it just starts to barely engage and it seems to slip into gear well
Old Oct 30, 2006 | 07:52 PM
Evoryder's Avatar
adjust pedal noob
Old Oct 30, 2006 | 08:02 PM
ONRAILS's Avatar
Are you serious? It will lock you out of reverse.. You should halfto put the car in 1st and then to reverse.
This keeps people from downshifting to 4th insted of grabbing reverse at 100mph.
Also adjust your clutch some.
Old Oct 30, 2006 | 08:04 PM
rraulston's Avatar
I installed mannys clutch and the engaugement is 3" plus or minus. Mine does this as well. So i got to thinking......we filled his tranny with Redline MT-90. I have used this from day 1. I wonder if this could be what caused it?? The other thing is maybe the twin discs need to wear in on the splines a little so as to find their center and float a little easier?? Just a thought......RRR
mrmiller
Jun 21, 2016 07:08 PM
z32cctx
Feb 27, 2014 12:02 PM
Ghost1t
Jun 17, 2013 12:54 PM
vboy425
10
May 30, 2011 10:32 PM
Oki Panoki
Driving Techniques
Dec 30, 2007 12:03 PM
