Evo engine knock normal?
Old May 14, 2003 | 12:15 PM
Meeyatch1's Avatar
Hey gang...my Evo is a high mile car now with over 10,120 miles so far in 3 weeks, and I am hearing a ticking or knocking noise from my engine especially when the car is cold started. It bothers me, but I am not sure if it is normal or not. Does anyone else have this? It seems to be far less evident when warmed up.
Old May 14, 2003 | 12:30 PM
mayhem's Avatar
try a search for 'ticking' or 'cold start'. there's a lot of info about this. i can't say it's "normal" because i don't like the sound of it, but i can say it seems to be common.
Old May 14, 2003 | 12:42 PM
WannaRace's Avatar
I definitely hear a knock noise on my car..dunno where it's coming from but sounds like the rear...Check thread "Warm-up Noise" and GoodLuck!
Old May 14, 2003 | 12:52 PM
leonard_shelby's Avatar
The Valves are VERY loud in the 4g63
Old May 14, 2003 | 01:01 PM
mayhem's Avatar
do you have a rough idle too? I don't have any ticking but idle seems like it sends random jolts. You can feel it in the seat and steering wheel. Anybody else's do this?
Old May 14, 2003 | 01:42 PM
Wonder if the hyper grounding kit would really make the idle better ?
Old May 14, 2003 | 02:05 PM
AutoXer's Avatar
I noticed it this morning. Interesting that I'm not the only one feeling it.
Old May 14, 2003 | 02:32 PM
mayhem's Avatar
Glad I'm not the only one. While it does it I watch the tach closely and listen to the engine even closer for speed changes but I see none.
Old May 14, 2003 | 02:43 PM
zyounker's Avatar
Valve tick is pretty normal on the 4g63.. just ask any DSM owner.
I have noticed mine does it on cold starts.. And i never drive the car until it is warm. And change the oil every 2500miles.. Well, i will be
-Zach
Old May 14, 2003 | 05:15 PM
zyounker's Avatar
um, if you are asking me i use the recommended Mobile 1.. But i have only changed the oil once so far..
Old May 14, 2003 | 08:31 PM
Crufty Dusty's Avatar
Re: Evo engine knock normal?
I had this noise on my E7 too. It makes the engine sound like a diesel. Apparently it is a known problem with air getting trapped in the lash adjusters. You can read more about it here.
HTH.
Old May 14, 2003 | 11:32 PM
DB8GSR's Avatar
Does it sound like one of your Honda cars? If it sounds like a tap dancing *****, then it's probably the valves. Valve adjustment perhaps?
Old May 15, 2003 | 08:40 AM
SuperchargedGTZ's Avatar
its the lifters....i had the same problem with my gride after installing the BLOWER, it isnt a problem
Old May 15, 2003 | 08:51 AM
AutoXer's Avatar
Our cars use Valve Lash Adjusters not Lifters. They are filled with engine oil. They are self adjusting, so no need for manual adjustment.
I noticed this problem with my 2000 Eclipse when I switched to Mobile 1 synthetic. I used to really notice it after an autocross. Sometimes it was so bad that it sounded like a mild rod knock. I believe the problem stems from the VLAs not being properly filled with oil. I also don't think that its anything to be concerned about. Its just a trademark of the 4G63T.
See... http://members.shaw.ca/costall/1000Q...#myengineticks
