Interesting info on Works tuned Evo...maybe the truth?
Old Nov 6, 2006 | 09:18 PM
tlclee's Avatar
Interesting info on Works tuned P2R Evo...maybe the truth?
Link to Norcal Evo discussion
From a member on Norcal Evo:
here are my logs from evo scan with a "works" p2r flash. i should have started logging at a lower rpm and stopped at a higher rpm. a friend of mine was with me, so he was logging while i was doing the driving. we're both new to evoscan datalogging so newbie mistakes existed....but its pretty self explanatory, "works" needs to re-tune my car.
this is on an eov ix mr at 9200 miles. everything stock except for p2r flash and works drop in filter. used 91 shell gasoline ( i know, i know...shell sucks. but was the only gas station nearby or would have ran empty to the bone)...third gear pull at night on an empty stretch of road in san mateo.
CoolantTemp RPM TPS KnockSum
182.0449 1687.5 100 0
182.0449 1718.75 100 0
182.0449 1750 100 0
182.0449 1781.25 100 0
182.0449 1843.75 100 0
182.0449 1906.25 100 0
182.0449 1937.5 100 0
182.0449 2031.25 100 0
182.0449 2093.75 100 0
182.0449 2156.25 100 0
182.0449 2187.5 100 0
182.0449 2250 100 0
182.0449 2312.5 100 0
182.0449 2375 100 0
182.0449 2437.5 100 0
182.0449 2500 100 0
182.0449 2562.5 100 0
182.0449 2625 100 0
182.0449 2718.75 100 0
182.0449 2781.25 100 0
182.0449 2843.75 100 0
182.0449 2937.5 100 0
182.0449 3031.25 100 0
182.0449 3125 100 0
182.0449 3218.75 100 0
182.0449 3343.75 100 0
182.0449 3500 100 0
182.0449 3625 100 2
182.0449 3781.25 100 2
182.0449 3875 100 2
182.0449 3968.75 100 2
182.0449 4093.75 100 1
182.0449 4218.75 100 1
182.0449 4375 100 1
182.0449 4468.75 100 1
182.0449 4625 100 0
182.0449 4750 100 0
182.0449 4875 100 0
182.0449 5000 100 0
182.0449 5125 100 2
182.0449 5218.75 100 2
182.0449 5343.75 100 1
182.0449 5437.5 100 4
182.0449 5593.75 100 4
182.0449 5687.5 100 4
182.0449 5843.75 100 5
182.0449 5968.75 100 6
182.0449 6062.5 100 6
182.0449 6187.5 100 6
182.0449 6250 100 11
182.0449 6343.75 100 10
182.0449 6437.5 100 12
182.0449 6562.5 100 12
182.0449 6656.25 100 14
182.0449 6750 100 14
182.0449 6812.5 100 13
182.0449 6906.25 100 19
Old Nov 6, 2006 | 09:30 PM
thatsMR2u's Avatar
thats some serious knock- but something seems up with it skipping 6 knock counts in one datalog at the end- he should see if the car is pulling massive timing or if its phantom knock such as a lose heat shield
and btw in the eastcost i get the least amount of knock with shell gas
Old Nov 6, 2006 | 09:50 PM
Warrtalon's Avatar
Yeah, show us timing next to the knocksums. It is a common mistake to just look at knocksums and assume the tune is bad, although it's of course a possibility.
Old Nov 6, 2006 | 10:55 PM
1.8t's Avatar
WTF is up with the coolant temps?
Old Nov 6, 2006 | 11:07 PM
tripperfx3's Avatar
Dang! I dont know much about tuning and logging, but i know thats pretty messed up. Also, here in GA Shell has some of the best gas around. I only use Shell and BP and notice a small improvement over Quiktrip and the such.
Old Nov 6, 2006 | 11:40 PM
Erik@MIL.SPEC's Avatar
You need to look at the data more closely before we start on our favorite past time...vendor bashing.
I myself am experiencing boost cut, but I'm not complaining that my XEDE sucks. I am still diagnosing the problem.
Old Nov 7, 2006 | 12:20 AM
tlclee's Avatar
This post is to show ppl some info on Works tuned cars. Here is another data log from another Works P2 customer:
Old Nov 7, 2006 | 12:42 AM
And timing during that run?
Old Nov 7, 2006 | 12:50 AM
kf6ytc's Avatar
you bought a flash that wasn't even tested on your car, what did you expect?
Old Nov 7, 2006 | 12:57 AM
Spec'd's Avatar
What's the OctaneFla? on that log ? ^^^
Old Nov 7, 2006 | 01:06 AM
tlclee's Avatar
UHHH?
Old Nov 7, 2006 | 04:35 AM
kf6ytc's Avatar
correct me if i'm wrong, but did works do anything other than ask your mods and blindly flash a file into your ecu, made sure it starts and charge you $600?
Do you expect to make power and not knock with no road or dyno tuning?
TJ
Originally Posted by tlclee
UHHH?
Old Nov 7, 2006 | 06:45 AM
Warrtalon's Avatar
Yes, kf6ytc, that's what they advertise, so that's what people expect. There are countless Dynoflash base flashes out there that work great. Base flashes are made more conservative for that very reason. No base flash should have such high knock sums, especially not when you pay $600.
Old Nov 7, 2006 | 07:16 AM
spdracerut's Avatar
what are the units for the 'airflow' value? I'm use to nissan's where it's given as a voltage. I find it a bit odd that the 'airflow' seems to peg '1603.95'. If that's the MAF maxing out, that would lead to the detonation.
Might just want to make sure these guys got the correct program also. Maybe they got 93 octane instead of 91?
Also, though I don't think too likely, worn out or too hot of a heat range spark plug.
Old Nov 7, 2006 | 09:05 AM
tlclee's Avatar
TJ
I never said they tuned my car....I saw this post on Norcalevo and wanted to share the info with you guys.
