BP7ES Spark Plugs ???
Old Nov 7, 2006 | 04:51 AM
GOKOU's Avatar
Too many opinions on what spark plugs to use. I wanted BPR7ES or BPR8ES but none left at that store so ended up with BP7ES. Want to know if anyone else is using these plugs or should I get them out ASAP
03 with BRS4 + alky.
Thanks.
Old Nov 7, 2006 | 04:58 AM
deadbeatrec's Avatar
Thanks.
do u mean br7es? i have never herd of bp7es but im not spark plug gru either.
Soon2BEVO's Avatar
The BR's are great. Ive been using them for over 40k miles now and I wont go back to the BPR's
Old Nov 7, 2006 | 05:06 AM
so then whats the difference between BP7ES and BR7ES?
Old Nov 7, 2006 | 05:08 AM
Soon2BEVO's Avatar
It was a misspelling, its BR not BP.
Old Nov 7, 2006 | 05:16 AM
EVOLVEU's Avatar
GOKOU, ngk bpr7es is in the stock heat range, it is recommended that you use bpr8es now that you are making ~100hp more than stock.
Old Nov 7, 2006 | 05:18 AM
EVOLVEU's Avatar
the difference between the two is one is copper the other is iridium
Old Nov 7, 2006 | 06:43 AM
Warrtalon's Avatar
No, that isn't the difference, EvolveU. The Iridiums have IX at the end. He may actually have BP7ES, because that nomenclature does exist. He needs to have either BPR7ES or BR7ES, but realy he should be using the 8 heat range, so BPR8ES or BR8ES. I would not waste my time with the 7s when running big boost on alky - the spark will get blown out.
Old Nov 7, 2006 | 06:46 AM
Nez136's Avatar
^+1
Old Nov 7, 2006 | 07:00 AM
MitsuJoe's Avatar
What are the thoughts on the stock plug then? I stepped back to the BPR7IEX (sp?) and it helped with P0300 although it may not be the best for power. Should I go back to the BPR8ES?
Old Nov 7, 2006 | 07:31 AM
GOKOU's Avatar
THanks. I'm quite sure it's BP7ES. I meant to buy BR7ES. I went with the 7 thinking that it will be okay since winter is coming.
So I'm guessing the verdict is take it out ASAP ???
Old Nov 7, 2006 | 07:33 AM
MitsuJoe's Avatar
If I recall the BPR7ES/8ES is a copper based plug where cold startup and drivability will be lost with what these plugs have to offer.
Old Nov 7, 2006 | 07:34 AM
Warrtalon's Avatar
I've never noticed any cold startup problems, and I've been using NGK coppers for 7-8 years.
You need to get 8s for the power you're making and boost you're running on alky, Gokou. Joe, I don't know your mods, so I can't answer your question.
Old Nov 7, 2006 | 07:39 AM
MitsuJoe's Avatar
I neither have had cold startup problems. I was only speaking what the norm is on copper based plugs.
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
flyingwangwang
Feb 26, 2012 01:50 PM
Countrystrong11
Sep 17, 2011 09:29 AM
Gary@MellonRacing
Oct 1, 2008 06:36 AM
GOKOU
17
Apr 12, 2005 07:17 PM
