80mm??? help me out .....
Old Nov 7, 2006 | 09:23 AM
06redMR's Avatar
ive finally decided and im about to purchase the RS-R DP and greddy EVO2 exhaust. before i do this i wanted to check with you guys. i noticed that the piping is 80mm on both of those peices and 3" is 76mm. do u think that extra 4mm could make any sort of negative impact on the performance of a regular 3" exhaust, or does it not really matter and i should just go ahead and order the part already. let me know what u guys think . thanks
Old Nov 7, 2006 | 09:25 AM
TURBevO8's Avatar
80/25.4 = 3.15". That isnt much more than 3". You'll be fine.
Old Nov 7, 2006 | 10:10 AM
DaWorstPlaya's Avatar
It doesn't matter, the wider the piping the better ...
Old Nov 7, 2006 | 10:19 AM
WTF_LOL's Avatar
Actually, it does make a difference. There is deffinetley TOO large. Don't forget about the scavaging (sp?) effect... With a turbo setup, larger is sometimes bettr but too big you get negative effects. It all depends on who you talk to driving style and your setup. I know Works claims that through thier R&D that they made LESS power with the 3 inch on a stock turbo. By the question I am guessing you have a stock turbo. 3 inch is as big as I would want to go. however, with a larger turbo you may want bigger. AMS uses a 4 inch exaust on thier setup for example
That being said, if you found a setup you really want and you don't care about the small details of how your car makes power, like every little tenth of a second. Then I would say that that small difference you will not notice from a 3 inch
Old Nov 7, 2006 | 10:54 AM
I was hoping noone would start this BS. It doesn't matter on a turbocharged car, the less backpressure, the better. Bigger after the turbo is better as it improves the VE, period. There are countless threads on this ...
Old Nov 7, 2006 | 10:59 AM
dubbleugly01's Avatar
There is no scaveging effect AFTER the turbo. When will people learn. FYI - The EVO 2 exhaust necks down to 2 1/2" where it bolts to the factory cat/ cat delete pipe.
Old Nov 7, 2006 | 12:04 PM
06redMR's Avatar
ok so if the rsr is 80mm and the evo 2 is 80mm but necks down to 2 1/2 where it connects to the RSR, does that make a difference in terms of performance? or is that just what it is
Old Nov 7, 2006 | 01:44 PM
I will make a little (read very little) difference as there is a bottleneck in the part that is 2.5 inches. You want it to be 80mm all the way through if possible ...
Old Nov 7, 2006 | 05:02 PM
06redMR's Avatar
i guess im just doing RSR DP w/ greddy evo2 catback . lets hope i dont regret it .
Jhurley_EvoVIII
For Sale - Cars For Sale
Dec 12, 2016 09:53 AM
Darkn3s
65
Jan 19, 2010 10:19 PM
bbyevo8u
36
Nov 8, 2009 06:30 PM
boostless
29
Oct 16, 2008 02:13 PM
Tsurara
Jun 6, 2005 04:18 PM
