Fueling a NX wet Kit
Old Nov 14, 2006 | 02:42 PM
Noogles's Avatar
Where are you guys running nitrous getting the fuel feed from?
I've always taken it from the shrader vlave on the GM fuel rails. Is there fuel rail adapter available?
Old Nov 14, 2006 | 10:32 PM
kjewer1's Avatar
I run an Aeromitive AFPR, which has 2 "inlet" ports. Normally one is plugged. I reduced that to 4an, and it makes for a very convenient fuel feed for a nitrous kit. If you are not running an AFPR, it will take a little doing. First things that come to mind are aftermarket fuel rails that have a 1/8th NPT gauge port you could use, and converting the line from the fuel filter to the fuel rail to an and putting a tee or a gauge adapter inline.
Old Nov 15, 2006 | 09:56 AM
Noogles's Avatar
i thought about doing an aftermarket fuel rail but i don't like the idea of the feed being before the #1 cynlinder, i could see some potential lean conditions when it comes one.
hutch959
Jan 2, 2017 04:33 PM
BGevoIX
Sep 24, 2009 10:28 AM
konstantinosIX
Jan 19, 2009 11:42 AM
djd24
Dec 16, 2006 12:53 PM
haze1995
Northwest Region
Mar 27, 2005 05:40 PM
