Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Perrin Fuel Rail issues
Old Mar 24, 2005 | 09:26 PM
haze1995's Avatar
Just installed the Perrin Fuel Rail and I had a few problems. First the fuel hose that came with the kit was to short. 2nd the top screw on the right side is too long, guess I will shave the bolt down. The main reason for this thread is: after installing the fuel rail the 3rd injector from the left was spraying a small mist of gas. I gently move it side to side and forward and back. The mist stopped. Is this something to worry about?
Old Mar 25, 2005 | 08:34 AM
little's Avatar
An injector that is spraying gas out is a problem. The most common problem that causes this is a pinched/damaged O-ring. This happens frequently when the injectors are put into the rail without greasing/oiling the O-ring. If this is the problem you just need to get a new O-ring, make sure to lube it up before re-installing.
Old Mar 25, 2005 | 10:07 AM
data_vr4's Avatar
I agree. Put new o-rings w/ lube cause lube makes the world go round.....and you should be fine afterwards. Keep an eye on it for a week or two just to be safe.
Old Mar 25, 2005 | 12:27 PM
jman425's Avatar
otherwise.. slap some meat on the extractor grill, fire up the gasoline spray and you have an instant hibachi grill
Old Mar 25, 2005 | 06:29 PM
haze1995's Avatar
turns out it was the O-Ring. I purchased 4 new one's (15 bucks!!!). Will swap them out in the morning. Thanks for all the help. Ryan
Old Mar 25, 2005 | 06:39 PM
lqdchkn's Avatar
In defense of Perrin The hose that came with the kit isn't too short. You use it with the supplied barb to replace the stock hard return. And It specifically says in the very detailed instructions that you do not replace the bolts in the factory order because as you said they won't fit. This kit is the easyiest fuel rail change I've ever seen/done (2hours max) and came with great instructions. Please read them!
Old Mar 25, 2005 | 08:31 PM
haze1995's Avatar
Yeah figured it out with out instructions. Was a bit flustered is all. Thanks for your 2 cents.
Old Mar 26, 2005 | 07:52 AM
voidhawk's Avatar
probably a little too late now, but take a look at this:
http://www.evolutionmr.net/forum/viewtopic.php?t=82
Old Mar 27, 2005 | 05:40 PM
MeKilla's Avatar
nice write up
stvbreal
14
Dec 28, 2009 05:10 AM
mick82907
Mar 7, 2008 05:43 AM
hawaiian_evo
Aug 7, 2007 11:38 AM
ITEM9
27
Jul 20, 2006 12:23 PM
silverEVO8
Feb 25, 2004 07:20 PM
