Trouble shifting gears
Old Nov 18, 2006 | 03:32 PM
haze1995's Avatar
First, I have a perrin short shifter.
Now the problem. Its started as a small issue awhile back. Now (today), I went to the car to go to work. Car wouldnt go into reverse. Checked all other gears and they wouldnt go in. The only gear that went in with some effort was 3rd. Its seems like the slots for the gears are gone. During freeway driving shifting isnt really a problem. When I am at a stop shifting into gears is a problem. This is really frustrating.
Isnt the powertrain warrenty for 60,000 miles?
I have 2004 Evo BTW
Old Nov 18, 2006 | 07:46 PM
haze1995's Avatar
anyone wanna help me out. I am taking it to the dealership on Monday.
Old Nov 18, 2006 | 08:07 PM
spdracerut's Avatar
Is the clutch disengaging all the way? Might need to bleed the system.
Old Nov 18, 2006 | 08:10 PM
haze1995's Avatar
It feels like it is but when I am pressing the clutch in all the way and let off the brake on level ground, the car moves a tiny bit. Its really strange.
Old Nov 18, 2006 | 08:15 PM
purevibez's Avatar
try bleeding it out, imo i think it would still be hard to shift on the highway aswell as dead stop and go driving. check the fluid in the res. aswell it might have gunk in it which is affecting the pressure. eliminate the possible problems one at a time starting from one side and work to the other. hope u get it fixed
Old Nov 18, 2006 | 08:18 PM
thisxguy's Avatar
get rid of your short shifter. i hear that they cause shifting trouble
Old Nov 18, 2006 | 08:23 PM
haze1995's Avatar
I really dont think this is the problem. I have had my shortshifter on the car pretty much since I bought it 2 years ago.
Old Nov 18, 2006 | 08:24 PM
haze1995's Avatar
Thanks. Its not perfect on the hwy, just easier than at a standstill.
Old Nov 18, 2006 | 08:31 PM
eponti's Avatar
but the old one back on and see if it will take care of the problem,if not maybe your clutch needs to be adjusted.
Old Nov 18, 2006 | 10:41 PM
haze1995's Avatar
went throught the gears while the car is turned off and they all engage smoothly.
Old Nov 19, 2006 | 07:42 AM
prj.evo's Avatar
What happens when you put it in gear with the car off, then push in the clutch and start it? Does the car hop or move forward at all when you go to start it?
Old Nov 19, 2006 | 08:43 AM
haze1995's Avatar
Havent tried that yet.
Old Nov 19, 2006 | 09:09 AM
nikkadanny's Avatar
same exact thing happens to me, i'm thinking about taking it to the dealership and have them look at it
Old Nov 19, 2006 | 09:19 AM
purevibez's Avatar
check the hydraulic cylinder(its where you bleed the clutch) if it slowly got worst as time went by as u said. im thinking that, or some other pressure loss somewhere. maybe a small fluid leak.
my 2 cents
hope u find it soon
BlueoctaneevoX
25
Oct 12, 2011 09:56 AM
Turvo
Mitsubishi TC-SST Discussion
Jan 31, 2011 01:38 PM
Hcaruso4
Lancer Tranny/Drivetrain Tech
Jul 2, 2008 02:42 PM
uSmC_08
Sep 15, 2007 08:00 PM
alex_alex
13
Dec 28, 2004 08:46 AM
