How to crush JDM MR DV?
Old Nov 19, 2006 | 05:03 AM
sparky's Avatar
What is the correct proceedure for crushing a JDM MR DV? How do you know how far to crush it? What tools are needed to do the crushing properly? Has anyone verified an increase in boost holding on the JDM DV's after crushing?
Any help woud be appreciated. We used to crush the stock, fuel pressure regulators on Buick Grand Nationals before adjustable ones were available. We'd put a socket over the adapter and stick them in a bench vise.
Old Nov 19, 2006 | 05:11 AM
kjewer1's Avatar
The correctmethod for the 1G bov is to crush it until it takes about 19"hg (using a mightyvac or similar) to just crack the valve off the seat. Going to 20" will typically make the valve fluttery. Of course this will vary somewhat with the level of vacuum your cams give you, so the best bet is still to take it one step at a time. The MR valve should be pretty stiff already so I would go in 2" increments at the most. 1" if you can tolerate the slow pace.
The idea is to get maximum holding power without it running like ****. The numbers may differ in this application, but the procedure still applies. This mod is proven to increase the 1g BOV's capacity, but I have no personal experience with the EVO valve.
Old Nov 19, 2006 | 07:31 AM
Warrtalon's Avatar
Put it in a vice and crush it uniformly without going so far that the nipple gets bent.
kelvinTME
Sep 17, 2012 05:44 AM
taylorgang
May 21, 2011 09:34 PM
bnr34rb26dett
Jan 20, 2011 06:47 PM
MysticMyth
Jun 30, 2004 08:37 PM
WannaRace
22
Dec 30, 2003 09:25 PM
