358 miles on engine and it's running rough..
Old Nov 22, 2006 | 12:36 PM
Methodical4u's Avatar
I checked the IC piping and such because I know the 9's will blow them off sometimes... but it's running really rough, backfiring, feels like it's really working just to let the clutch out and get it running.. shuts off easily AND the service engine soon light is on.. do the pipes come all the way off when they blow? Or could one just be lose and I need to take it apart and look at it? It's under warranty, but driving it an hour just to fix something lame sucks. Any ideas?
Old Nov 22, 2006 | 12:43 PM
Smike's Avatar
Still sounds like a IC pipe. Did you check all the IC piping? Like the LICP or the post-IC pipe behind the driver side bumper (you cannot get to those without getting under(into) the undertray?
Whenever I blow mine off they are all the way off. Driving on it more and more is just going to foul up the 02 sensors.
Old Nov 22, 2006 | 12:47 PM
AlwaysinBoost's Avatar
where are you located? why not take it back to the dealer?
I just looked at the pipes from in front of the humper and they both look to be on.. I don't know if the pipe blew off somewhere else or if it's lose somewhere and I can't see it.
Old Nov 22, 2006 | 12:52 PM
Smike's Avatar
Now is the "humper" the driver or the motor?
They could have blown off the clamps or the clamps are very loose. So under any boost they are expanding off the piping, giving you crappy driving.
Old Nov 22, 2006 | 12:54 PM
my bad... Bumper :-D
Old Nov 22, 2006 | 12:56 PM
I haven't driven it though.. I just started it up and it was missing and so forth and I thought it probably wasn't a good idea and I was pretty pissed, but then I remembered the pipes coming off sometimes so I wasn't sure if that was the case.. I just went out this morning and moved it because some guys were here doing some work.. it wasn't even under any extreme boost.
Old Nov 22, 2006 | 01:46 PM
apexsilver9's Avatar
call the dealership and have them tow it and take a look. there shouldnt be any charge if its under warranty.
Old Nov 22, 2006 | 01:57 PM
yeah I think i'm going to do that.
Old Nov 22, 2006 | 02:11 PM
I don 't know if this has anything to do with it, but it's about 35 degrees here today... a brand new car should run correctly in pretty much any weather but I don't know if this has anything to do with it or not.
KRod223
Aug 12, 2021 12:08 PM
SOG RA
52
Jan 24, 2014 11:23 AM
whitedemon
Jun 4, 2011 12:29 PM
yellowrocket
Northwest Region
14
Apr 21, 2009 03:56 PM
joshthegreat
Lancer Troubleshooting
25
Mar 8, 2006 03:18 AM
