CEL not coming on for disconnected catback o2 sensor
Old Nov 29, 2006 | 01:21 AM
Positron's Avatar
So I finished up putting back my stock downpipe, stock evo9 catback and 3" resonated testpipe with o2 bung hole.
I put on the o2 sensor onto the testpipe. I instantly notice this will not work because the o2 sensor is too long and will rub against the driveshaft. Basically I'm screwed. Theres no place to put the o2 sensor at all.
So I tie up the o2 sensor wiring and leave it hanging on the car. I drive to work and back. The CEL does not come on. Maybe I avoided a bullet for now.
I plan on getting another aftermarket catback anyway. Should I be worried driving around for now like this? Any idea what happens when the o2 sensor is not sensing or reading anything?
Old Nov 29, 2006 | 05:44 AM
Hyper_Rev's Avatar
Your going to ruin your 02 sensor by leaving it hanging like that and driving around also your CEL is going to come on just give it time. If you have to leave the o2 the way it is I would suggest wrapping it up in something. Honestly I would just disconnect it and save yourself the money from buying a replacement sensor.
Old Nov 29, 2006 | 06:03 AM
rcheung's Avatar
The O2 sensor check engine light doesn't always come on right away but if its not hooked in to the exhaust correctly it eventually will.
Old Nov 29, 2006 | 06:29 AM
dsmfan95's Avatar
The o2 sensor goes into the cat-back. More than likely, the bung in your test-pipe is for a wideband.
Old Nov 29, 2006 | 09:03 AM
newbieEVO8's Avatar
If he is has a IX then the o2 goes in the Cat, where our VIII's are in the catback.
Old Nov 29, 2006 | 09:37 AM
Ralph's Avatar
Turn your test pipe upside down.. temporarily ?
Old Nov 29, 2006 | 11:53 AM
Positron's Avatar
I'll see if I can turn the testpipe upside down or not.
I tied the o2 sensor so it would not drag onto the ground/floor. The o2 bung on the testpipe I have has a plug for it. So I used that.
Old Dec 4, 2006 | 07:25 PM
freddiet's Avatar
see how hard it would be to extend the wires just to get enough to diy spark plug fouler trick , that is of course if that works on a 9??
Old Dec 4, 2006 | 07:28 PM
hotrod2448's Avatar
I'm thinking the test pipe is not clocked the right way.
Old Dec 5, 2006 | 05:44 AM
Jersey Dino's Avatar
I have the turbo xs turbo back on my 9. The system has a bung in both the catback and the test pipe and the DP. I put my sensor in the catback. its been there since last week with no CEL. The non fouler worked at first but then it broke in half beasue of clearance issues. If you are familiar with these little non foulers, you will realize that they are dtwo peices. The 02 sensor only fits inside the one. the other is too shallow. I just drilled the one out enough for it to fit properly. By doing this I have eliminated the clearance issue, and it looks like the sensor is far enough out of the exhaust stream to not throw a CEL.
Old Dec 5, 2006 | 08:31 AM
20psiMR's Avatar
Its not going to ruin it by dragging on the ground. Its going to ruin it because its getting power and reading the wrong air right now. Im pretty sure those o2 sensors need to be heated up when they are running. Turn your testpipe upside down. Or better yet, run the aftermarket exhaust you bought and put your cat back on. Those sensors are $300 plus, you dont want to ruin it.
Most exhausts you buy are going to come with another bung for a sensor, since VIII's sensor was after the cat. Either that or a muffler shop will charge you like 20 bucks to put another bung in. I just did that for my wideband, took 5 mins.
Old Dec 5, 2006 | 08:42 AM
cfdfireman1's Avatar
Weld and you're done.
http://www.innovatemotorsports.com/x...cat=250&page=1
Silver06evo9mr
Nov 11, 2014 10:55 AM
RedEvoxGSR
Jun 15, 2010 10:47 PM
commandwolf
Oct 26, 2009 07:53 AM
bboy_RES
Sep 21, 2007 09:31 PM
crow
Feb 27, 2005 11:08 AM
