squeaky pedal
Old Dec 8, 2006 | 09:18 AM
daisaw1219's Avatar
squeaky pedal
Everytime i push down on the clutch no matter if the car is on or not it squeaks....It sounds like a cat almost. Has anybody experienced this before or does anybody know a fix.
Old Dec 8, 2006 | 09:25 AM
cmz's Avatar
cmz
I have the same type of problem. usually occurs after I've been driving for a while: not when it's cold, and it doesn't occur when the motor has just warmed up (from sitting overnight for example), I have to have been driving it.
I've adjusted my clutch peddle, that had no effect.
Bled the clutch, still there.
Changed the tranny and diff fluids, still there.
Took it to the dealer: they greased the peddle and the rod the goes through the firewall to the clutch's master cylinder, didn't help.
The one and only interesting thing I noted, and I haven't pulled the tranny to look at the clutch yet, is that there is a small tear (facing the radiator) on the slave cylinder's boot. It is not leaking fluid though.
I too would like to know if anyone has had this type of issue and firgued it out.
Old Dec 8, 2006 | 10:58 AM
jrsimon27's Avatar
bump
Old Dec 8, 2006 | 11:01 AM
SteveosEvo's Avatar
I have a slight squeek when I push my clutch pedal in. Only time I can hear it is if radio is off. I have learned to just deal with it, but it would be great if you find something out.
Old Dec 8, 2006 | 11:15 AM
coffeeslug's Avatar
I had the squeak, and then I bought a can of WD40. Solved my problem.
Old Dec 8, 2006 | 11:29 AM
jrsimon27's Avatar
were did you spray it??
Old Dec 8, 2006 | 11:38 AM
redevo58's Avatar
i have been having the same problem with my evo. from several trial and errors on trying to figure out the problem i have come to the conclusion that its the spring on the clutch rod, and that spring rubs on the adjacent metal plate. If you get under the dash console and push in the clutch with your hand you can see the spring close and when it does you can see it the meta plate. I have tried greasing the metal plate and the spring and it does help stop the squeaking noise, but it only helps for a few days. I have also tried prying the spring with a screw diver but that is also a temporary fix.
Old Dec 8, 2006 | 09:39 PM
daisaw1219's Avatar
there has to be a particular cause of this becasue alot of older evo's dont even have this problem....the sound does effect driving but its just so annoying in stop and go traffic.
Old Dec 8, 2006 | 11:16 PM
dabie's Avatar
I recently started having the same problem. The noise occurs when I depress the clutch about halfway down, even if car is off. I only have 1600 miles on my car!
Old Dec 9, 2006 | 09:47 AM
jrsimon27's Avatar
bump for more info
Old Dec 11, 2006 | 09:04 AM
coffeeslug's Avatar
the clevis pin
Old Jun 1, 2010 | 06:59 PM
MarylandEvo's Avatar
I'm not sure if I'm having the EXACT same problem as you guys. Tonight after driving for about 15 minutes (no crazy driving, just cruising) I noticed after I turned the car off a weird noise comes about when I engage the clutch. I get a squeak...
Now, my WRX had the same thing happen to it and my clutch was going up. I hope to god that isn't the case here. I have a stage 3 ACT clutch and just bolt ons. No cams, no meth, and stock turbo.
Anyone have any further insight? possible throwout bearing bad?
Should I be worried?
Old Jun 1, 2010 | 07:03 PM
manray's Avatar
Mine had been doing this for around 2 years and no problems were present other than it being annoying
Old Jun 1, 2010 | 07:19 PM
TS8's Avatar
TS8
I've sprayed a heavier coat of lubricant (anti-rust) around the clutch rod and return spring area behind the pedal. (WD-40 is OK.)
It will quiet down the squeaking for a few months at least.
Any moving area will need some lubricant periodically.
I also spray the throttle area, my APS twin vent BOV and turbo actuator area from time to time.
Also, I think it helped my throttle shaft seals from leaking for the past 7 years @ almost 80K.
Also, make sure the fasteners around the clutch pedal assembly are all tight.
Old Jun 2, 2010 | 06:12 AM
barneyb's Avatar
I had this problem with a DSM - sprayed the moving parts under the dash to no avail. It was the seat squeaking.
Igaly1021
Jun 24, 2017 11:39 AM
jeromski2003
Jun 11, 2010 10:01 PM
dipsetinallday
18
Aug 17, 2009 10:05 PM
wilson1
20
Jul 31, 2005 11:41 AM
