alky and explosion in sheet metal intake manifold
i was reading thru this thread:
https://www.evolutionm.net/forums/sh...d.php?t=221276
is there the possibility that "pooling" and accumulation of fuel(methanol) in the manifold that cause this?
Anyone ever had this happen in a stock/cast manifold?
My sheet metal intake survived for a long time using meth befor one too many back fires blew it up, and I had a few backfires with the ported stock intake before I started shifting out of 1st gear at a lower RPM to avoid hitting the rev limiter. I think that if you backfire enough on the stock intake you will cause damage of some kind eventually (blow off vacuum lines, damage to throttle plate, etc..) so avoid the backfires guys
Keith
Keith
Originally Posted by Ultimate CC
it can happen but very unlikely with the stocker...
