DYNO EVO9 USDM Mivec map VS JDM Mivec map
Old Dec 14, 2006 | 01:16 PM
QAT-R's Avatar
Interesting...might be getting into a JDM IX in a few months.
Old Feb 12, 2007 | 08:03 PM
EVOINVASION's Avatar
thanks for the post for us mivec owners
Old Feb 12, 2007 | 08:56 PM
CBRD's Avatar
i am using a vvt map very similar to the jdm on the cars i've been tinkering with...
didnt see as much gain or loss as u have, but then again, im using a mustang dyno.
cb
Old Feb 13, 2007 | 06:19 AM
240Z TwinTurbo's Avatar
Originally Posted by vwjeff
, he is in the 13.5's at 4k, under max boost
If he is not picking up knock then it would be OK regardless of the leaner AFR's. I would personally try to richen it in that area and then add some additional timing to see if I could get some additional power. Leaner AFR's is a good sign the motor picked up flow(power). BTW, wide band O2's, depending on the brand, can have significant variations in the readings. I ran an FJO unit on the dyno and saw completely different AFR's than what the Dynojet was saying. AEM on TT Viper had different O2 values than that of the DynoJet.
Old Feb 13, 2007 | 06:24 AM
KevinD's Avatar
i also noticed siginificant improvement in low end torque with the JDM mivec map. this is an evo 9 with nothing but downpipe, catback, and boost turned up a bit with my tune. notice that there is about 45 ftlb increase in torque all throughout the low end:
Old Jun 3, 2007 | 05:09 PM
mrfred's Avatar
Is the only difference between the two sets of curves the MIVEC mapping (stock vs JDM RS MIVEC)?
Old Jun 3, 2007 | 05:21 PM
LY03-EVO-VIII's Avatar
with the JDM mivec maps did you do the fuel timing as well or just the MIVEC map itself? because the fuel timing maps look completely different from ours.
im running the JDM mivec map also just not the fuel trims.
feels better and i havent had any problems.
but thanks for all the info.
Old Jun 4, 2007 | 03:34 AM
aalzuhair's Avatar
Originally Posted by MR 600
I hit 22 psi then down to about 18 psi at redline. this run was on 91 octane.
Dude, why are you using 91 ??? saving money for the Cosworth cams .. hehehe
Could you post the JDM GSR MIVEC map?
Thanks,
Az
Old Jun 4, 2007 | 10:27 AM
20psiMR's Avatar
91 is all we get here in California and Nevada. I think Arizona is stuck with it too. Trust me, I would be running 93 if it was available. I cant justify the $5.00 a gallon 100 octane pump price either when Im just putting around town.
Old Jun 4, 2007 | 11:03 AM
JDMevoBOOST's Avatar
yepppp....all of our cars will make more power if we lean it out....but that doesn't mean it's safe.....ROFL....
Margin of safety FTW
Old Jun 4, 2007 | 01:42 PM
rjdevo9_mr's Avatar
I got a chance to dyno my EVO9 MR tonight.
Mods are: Drop in K&N - DC Down Pipe - Greddy Ti Exhaust - EBC
on pump gas, my EVO made: 303 whp / 275 wtq
I had the ECUFLASH and EVOSCAN (cable hooked up an all) ready and running to start tuning, but after looking at my A/F ratio on the dyno, it looked very good and very little room to improve. and since i was getting more parts soon, i decided to stay as is.
I then figured since i already paid for an hour on the dyno, i might as well try to upload a JDM MIVEC map from a JDM GSR. (not sure if the JDM RS is better/different)
Same boost on pump, did not change a thing. my EVO made 306 whp and 289.8 wtq, picked up 3 whp and 15 wtq.
Best part is the area under the curve. there were areas that were 22 whp and 23 wtq higher. much smoother graph and faster spool with better midrange power/tq
Very happy with the final result. coming up next are a set of the Cosworth cams
nice numbers bro!
Dead-Man Inc
Oct 4, 2006 07:29 PM
Rich@Orbital
Aug 29, 2006 09:02 AM
white venom
Aug 12, 2006 11:12 PM
ProccoEVO
Aug 13, 2005 02:18 PM
TRDHarrier
Jul 29, 2005 03:33 PM
