Can acceleration with low fuel cause engine skip?
Old Dec 20, 2006 | 06:24 PM
Markos's Avatar
Noob question: can heavy acceleration with low fuel cause a breakage in fuel flow to the engine? Here is what has happened to me twice:
- Fuel light on
- Accelerate hard in 3rd
- Hit about 5.5k rpm
- Engine jumps/skips (best way I can describe it. Feels like a misfire or backfire)
- Refuel at about 12.5 gallons meaning at least 1.5 gallons (I think) were in the tank
Does the fuel exit from the front of the gas tank? I've had this happen both on the street and at the track.
I do have a few mods (all WORKS products installed at WORKS)
- Aperture Throttle Body
- P2 Flash
- TB Exhaust
- High-Flow Drop-In Air Filter
Thanks in advance for any advice!
Old Dec 20, 2006 | 06:38 PM
s10v8's Avatar
- Fuel light on
- P2 Flash
- TB Exhaust
Yes.
Old Dec 20, 2006 | 06:54 PM
kaj's Avatar
kaj
so.. you were wondering if being out of gas would make your engine hesitate/die??
Old Dec 20, 2006 | 07:44 PM
HeLLA JDM y0's Avatar
no way, that's impossible!
Old Dec 20, 2006 | 07:56 PM
Roldy's Avatar
It's pretty common when you're auto-crossing or tracking your car with low fuel. The fuel slushes around inside the gas tank when you do hard driving and hence starves the engine of gas for a second. In your case the so called "skip" is what happens.
Old Dec 20, 2006 | 08:58 PM
skoarpio's Avatar
that sounds about right happened to me alot in my 2000 Nissan Silvia when i was out drifting and stunting but that was only after a long period of time though depending on what you are do it can cause a "stall" like condition which would cause the engine to studder or jump
Old Dec 21, 2006 | 12:29 AM
Markos's Avatar
Cool - wanted to be certain. Thanks.
As to the out of gas comments, I had 1.5+ gallons in my tank each time.
Old Dec 21, 2006 | 08:31 AM
jmartinez1170's Avatar
yes
Old Dec 23, 2006 | 11:58 AM
kaj's Avatar
kaj
but it was low enough that your light came on. that means you were really low. apparently, at least low enough to keep away from the fuel pickup.
either way, now you know. and knowing is half the battle.
MRLancer05
Jul 27, 2016 03:52 PM
blueprint
E85 / Ethanol
Sep 29, 2014 03:53 PM
ElectricBlueIX
Oct 30, 2013 03:44 AM
delkat
Feb 17, 2010 10:16 PM
