Buschur's Turbo Choices
I didn't point out the fact that you guys use a 44mm compared to their 38mm because that wouldn't be a reason why their kit costs more.
All I did was highlight the obvious.
I didn't know you guys included the turbo outlet pipe to adapt to the LICP (other brands, anyways). That'll save me money (if I go the 35R route, which I prefer your kit).
Let me know if you have any other questions on the kit. I'll be glad to help you out.... or anyone for that matter.
Spool up.... I can not comment on that right now but I will be able to shortly. Shearer just finished mine.
Im sending it out to be coated and then it will be installed. I will make a post once its installed and tuned. Anytime!
I'll be sure to PM you with the questions I have.
i stole jrods quote for my sig.
im interested in the 3065 in the future if i end up going to a stroker motor since i do track and autoX im kinda leaning towards the 50 trim..
what do you think the spoolup would be with a 2.4l stroker on the 3065?
Glad you liked it. lolI wouldnt recommend the 50 trim unless that what you REALLY want. The 20G-9LT flows the same amount of air and makes identical horsepower for substantially less money. 20G-9LT = $1700 Vs 50 trim = $2995. Less lag on the 20G-9LT for less money and similar power.
The 3065 on a stroker works really well. We have done a few of them here and they are fun cars to drive. Spool is like another 300rpm sooner or so. I dont remember exactly. Im pretty sure its around 4000rpm though.
The way I present turbo choices to customers is in this order. 20G-9LT, 3065, 35R, 37R, Etc.... I leave out the 50 trim, 3076, etc... there are just better options for power for less money or the same amount.
Jrod, do you guys at BR feel that getting a 20gLT is a worthwhile (significant/noticeable) upgrade from a stock IX turbo?
any noticeable midrange gains besides just the extra 30-35whp on the top-end?
will this turbo be as fun to daily drive (low-end torque) as my stock IX?
In a nutshell...... Without a doubt it will be a good upgrade over the stock turbo. It offers more than just 30-35whp over stock. Most are seeing 40-50whp with the right combination of parts. The turbo is proven to run high 10's / low 11's numerous times.
With the correct supporting mods its a straight up BLAST to drive! Lag isnt much more than stock. A few hundred RPM.
This subject has been discussed time and time again. A search will net you ALOT of information on this turbo as well as feedback and results from other members.
How much gains Do you usally see?..
