My dyno result, just under 300whp
Old May 22, 2003 | 04:16 PM
wing240's Avatar
Thanks dude for the info!! I found one 4 miles away from my house.... I am going to get some today...
also, my full tank of gas can only go around 170 now, after the fuel adjustment from the emanage..
you guys outside of CA see how lucky you are..
Originally posted by sanjaya1
Hey, I live in LA county and I have found a few 76 stations that carry 100 octane race gas. What I do is pump about 3.5 gallons of 100 and the top off the rest with 91 to get 93+ octane mix. Go to www.76.com and do a search to see if there are any close to you. There are some that carry the 10 gallon drums of racing gas, but only a few that have it at the pump. I do to one in OC, close to my work, one in West Covina and another in Diamond Bar, which are close to home. All three are actually just out of the way to be annoying, but I still go almost every other day. There are closer ones with the drums, but I would much rather drive a little extra to be able to pump it at the station. The price per gallon for 100 octane ranges from about $4.50-$5.50.
Old May 22, 2003 | 09:37 PM
1QWKEVO's Avatar
I know this is easier said then done, but keep your foot out of the pedal and your mileage will increase, LOL
It's not possible to have 2 different settings on the emanage or turn it off or sometihng so it goes back to a stock fuel curve? I know boost controllers aren't too much of a problem.
Old May 23, 2003 | 12:08 AM
gunzo's Avatar
Your lambda reads very high .. check out some of the posts from MLR .. I run AF ratios and I'm running 11.5-11.9 for the emanage.. (~0.8-0.83 lambda) The only thing I couldn't get to run properly is the ignition ..
2 things that I can assume for the wavy graphs .. your ECU is retarding ignition or the crappy ignition (or sparkplugs) is not up to it .. That can also account for the higher than normal Lambda readings ..
Old May 23, 2003 | 12:11 AM
Drivemecrazy's Avatar
I'm late...
It's my guess,
that dyno's pickup power and torque resolution was small(narrow?).
that's why graph drawed little choppy.
In this case of you need little adjust fuel.
droped area 5200~6300 need decrease fuel
and after 6500 need add fuel.
I don't know what differ you tested dyno and it's character.
But with this dyno result, I will try to adjust your data.
Originally posted by wing240
Kevin, can you help me on this ?? I was wondering why it's like that too...
Old May 23, 2003 | 12:47 AM
1QWKEVO's Avatar
anyone care to translate that to english?
Old May 23, 2003 | 01:01 AM
You right...
It just Alphabet ^^;
Always english makes me crazy...
Old May 23, 2003 | 03:45 AM
ChillinEvoVIII's Avatar
In Timeout
do u have the emanage / eo1 together... i just ordered them both.. im pretty sure u can keep diff settings if u get the emanage to run on your eo1 screen u get more options thats y i got the combo
Old May 24, 2003 | 11:27 PM
2race4REAL's Avatar
We have both of them too. Since you already ordered, stay with where you purchase.
Old May 24, 2003 | 11:56 PM
MrBubbler's Avatar
yea im located in calabasas california, and i got a 76 with 100 octane about 10 min away from my house! but anyways i would like to come down and get prices on all those modifications and so on and so forth! ive been holdong out on all modifications waiting for the good **** to arrive, you guys seems to be on top of ur game, keep up the good work!
Old May 25, 2003 | 01:01 AM
2race4REAL's Avatar
Come to Road Race Motorsports / Engineering where Mitsubishi TV commercial took place at Santa Fe Spring on Monday between 10am to 3pm.
We will be there in between that time to test U.S. Lancer and meet some Evo cars.
VRP
May 16, 2015 04:55 PM
credditt
Evo X Dyno Results
10
Apr 5, 2012 06:29 AM
KevinD
North Texas Evo Club (NTEC)
21
May 4, 2011 03:15 PM
HybridKOOP
Evo X Dyno Results
13
Jan 22, 2009 09:55 AM
Gruppe-S
70
Feb 24, 2006 08:00 AM
