hks rs intake causeing car to stall?
Old Dec 26, 2006 | 02:41 AM
riceball777's Avatar
ok i have a slight stalling issue. i would like to know how to fix this and if it is coused by my hks rs intake.
only very low throttle and low speeds, like stop and go traffic or going up a hill very slowly on first gear after i let off the gas in first gear and hit the clutch or put the car in nuteral, the car will run super rich and will stall out if i do not give it more throttle.
i just bought the car so i'm not 100% sure the intake is causing this. but i read that it might be. i think its something to do with the maf sensor geting a wrong reading and making the car run rich.
most are just tbx, hks intake and hks 272's and boost controller set at 20psi
Old Dec 26, 2006 | 03:06 AM
dxbevo9's Avatar
is the car tuned?
Old Dec 26, 2006 | 03:07 AM
yes the car is tuned at tt
Old Dec 26, 2006 | 03:48 AM
Paikman GTR's Avatar
do you have an aftermarket BOV?
Old Dec 26, 2006 | 04:21 AM
fusionchicken's Avatar
just take it back to tuning tech and have alfred take a look; it's the quickest way to solve this problem without people here taking guesses here and there IMHO.
good luck. hit up www.socalevo.net, TT as well as Road Race Engineering are both pretty active there to give you some good advices/help.
Old Dec 26, 2006 | 04:26 AM
evo150's Avatar
+1...what is vaccum at idle?
Old Dec 26, 2006 | 04:41 AM
vaccum is -14hg at idel. is that low?
i'm running the stock plastion bov which by the way sucks and does not even hole 20psi and leaks like 10% of the time
Old Dec 26, 2006 | 09:08 AM
steevo's Avatar
That vaccum should be normal with your cams. Definately agree on taking it back to TT for the idle problem. With the tune, you should be ok. If you think your stock bov is leaking, replace it with a JDM IX DV.
mc14
70
Sep 2, 2015 12:25 AM
bbak11010
Apr 20, 2011 01:26 PM
riceball777
10
Feb 21, 2007 12:53 PM
LancerEVOmann
15
May 4, 2005 02:31 PM
EVO316
14
Oct 3, 2004 08:30 PM
