transfer case leaking oil
Old Jan 2, 2007 | 10:24 AM
R3dline's Avatar
btw did it sound like this? http://youtube.com/watch?v=HErBOCcIIhg
Old Jan 2, 2007 | 01:12 PM
Evo_7's Avatar
In my case the t-case oil was going into the transmisson...
The second time my t-case oil started leaking after some launches...so i got it fixed
but now again as we speak its leaking not much but still...so i am gonna get it repaired again and also ordering Shep Trans Stage 2 with cyro plating...
Old Jan 2, 2007 | 02:19 PM
honda-guy's Avatar
not that loud, just a high pitch sound under heavy load (wot). sounds like when you're driving in reverse (because of straight cut gears). no sound when the car is coasting in neutral.
Old Jan 2, 2007 | 02:20 PM
honda-guy's Avatar
where did you t-case fluid leaked from?
Old Jan 2, 2007 | 02:44 PM
Evo_7's Avatar
some where in front...
Old Mar 6, 2007 | 10:58 PM
Devil_Evo's Avatar
I have the same problem .... oil leak from the breather
first i though its leaking from the seal ... i changed the seal but its still leaking then i saw it leaking from the breather ,,, what to do now ???
Old Mar 7, 2007 | 05:09 AM
honda-guy's Avatar
if it's leaking from the breather, then you have the same problem i had. you have a bad seal between the tranny and t-case and tranny fluid is getting into your t-case making it over flow. remove the t-case and fix the problem before you get the death whine unless you got it already. tranny fluid is not good in the t-case.
seal N 7 was bad
stunna2o1
Jan 25, 2016 07:02 PM
stunna2o1
12
Jan 19, 2016 11:44 PM
allday10sec
24
May 2, 2009 07:52 PM
EvoIXMR
15
Oct 22, 2008 07:50 AM
SAfrican
Jun 10, 2007 08:14 PM
