!!The Best BOV For evo 9 Recommend!!
If you want the sound without the stalling go for a twin vent like the APS or the GFB Stealth FX...they both work well and give you the sound you desire.
And anyone who thinks its ricey to want a nice sound should take a look in their hypocritic mirror cause anyone with an exhaust bought their specific brand because of how its sounds.
get the HKS Super Sequential with a recirculation kit. this BOV has a design that is different to most others on the market. the boost pressure helps to keep the valve shut and then opens with the help of the vacum instead of the spring fighting the boost pressue to stay shut. this design can support massive amounts of boost. there is also a "racing" version from hks that can handle 45psi if I remember correctly...
DV Tech - good read:
https://www.evolutionm.net/forums/sh...d.php?t=209640
the stock 9 is the best for almost all applications. basic bolt-ons with a tune.
the only time you should change the stocker is when you are running high boost with a bigger turbo. Or if you go with an aftermarket EMS.
Go back to the Stocker!!!!
