How to fill a transfer case v2.1
Old Jan 3, 2007 | 02:19 PM
rraulston's Avatar
Ive done so many of these, i get tired of how long they take to correctly fill. This is a 60 second job that takes 10 minutes to get it just right. SO.....while doing one last week, i had an idea. Fill it from the bottom.......O.k. O.K. sounds dumb, but it aint. I used a rag and put my fill pump in the drain hole and pumped away. When it started to weep, i pulled the rag and plugged it. I lost virtually nothing and presto!! Now the funny thing is i got about another 150ml more in it this way!!! Just thought i would share!! Ray
Old Jan 3, 2007 | 02:23 PM
rraulston's Avatar
And one more thing, ive done alot of these that are virgins. The factory isnt even comming close to getting these things full. First thing i would do knowing what i know, is have this level checked as soon as i got the car........RRR
Old Jan 3, 2007 | 02:48 PM
marksae's Avatar
What's wrong with filling it through the fill port? It only takes a few pumps before it fills up. There's definitely a lot more room for error by attempting to fill it through the drain port.
Old Jan 3, 2007 | 03:01 PM
rraulston's Avatar
You just said it!!! A few pumps and its full!!......NOT all the time!! If you dont rotate the trans and recheck and rotate and recheck you get what alot of other people got, a half full xfer case!!! These things need to be burped several times or you think its full and its not. There is no error through the bottom. I get more in faster. Next time use a mirror and flashlight to look in the fill port when you think its full, you might be suprised. And you are right, there IS nothing wrong with filling it through the fill port, i just think my way is safer/easier/faster. RRR
Old Jan 3, 2007 | 03:27 PM
A418t81's Avatar
What do you mean by "rotate the trans?" Crank on the car with the CAS unplugged or something?
Old Jan 3, 2007 | 03:30 PM
TouringBubble's Avatar
You should be able to just spin a wheel and the gears would rotate.
Old Jan 3, 2007 | 03:57 PM
marksae's Avatar
I've taken my t-case apart before (quaife install). There are no pockets where air can get trapped in. The only gears that use the gear oil is the ring and pinion. I just overfill the t-case until fluid starts dripping out of the fill port. That's what the shop manual recommends, that's what I've been doing. My car has survived 13 track days. I think this method works.
The one thing I've noticed is that the t-case fluid gets much darker compared to the rear diff fluid in the same amount of miles. So I change the t-case fluid twice as frequently as the rear diff.
Old Jan 3, 2007 | 04:15 PM
rraulston's Avatar
Thats how i do it...
Old Jan 3, 2007 | 04:17 PM
rraulston's Avatar
Of course this method works, if you are attentive. Alot of these noobs comming to my shop AND from the factory fills are half!!!! All i care about is sending them on their way FULL!!!!
Old Jan 3, 2007 | 04:24 PM
mrfred's Avatar
It seems like very little oil came out of my xfer case when I drained it for the first time two weeks ago.
Old Jan 3, 2007 | 04:26 PM
rraulston's Avatar
YEP!!! I see it all the time............Folks, if you are on stock oil, just check it real quick!!! m2c..........
josh_evo9
26
Dec 29, 2016 03:28 AM
Canada_Comp
16
Jun 9, 2015 12:21 PM
godzuki
Jun 14, 2012 08:52 AM
Russell K
44
May 26, 2006 07:58 PM
osunick
Apr 12, 2004 08:05 PM
